webZplus
Dec 27, 2016Star
ReadyCloud not connecting
Re: ReadyNAS 202 / Firmware 6.6.0 / ReadyCloud Client v1.15
So it's nearly a year that I have been trying to connect my NAS202 via the ReadyCloud client (v1.15), and I still can't connect using my Windows 10 laptop, all I get is a message that says the NAS202 is online, VPN disconnected...
and now today even my iPad and iPhone fail to connect using the App (v1.5.9) I am able to see all the shared folders, and even sub folders, I just can't navigate to view files (the message I get simply says ERROR The operation couldn't be completed at this moment, try again) - I have searched for hours for a solution and I'm disappointed that this 'consumer level' product just doesn't work reliably and simply...
and don't even get me started on the 'wake on lan' function - when I bought the NAS unit I also bought a UPS that will turn the NAS off when the power goes out and the battery is low... this is fantastic except you have to turn the NAS unit back on manually as the wake on lan requires the use of a further, non Netgear app to control it, again this works locally but will not function via the internet...
I'm not sure what the solution is but given how much time I spend away from my office it would be really great to have access to all the files I need without having to rely on USB drives to take data with me !
2016-01-12 10:25 AM
Hello, I have been having the same issue and have similar versions of the programs Windows 10, version 1511, Build 10586.36 and ReadyCLOUD version 1.9.1249.412 - since these upgrades the ReadyCloud client is unable to connect locally, via cellular or external wi-fi connections, my ReadyNAS (NAS202) shows up as a network drive and I can connect to the drive with read/write access no problems over my local network, I can connect to the web version of ReadyCLOUD and access files remotely via this method if required. Luckily my old Windows 7 laptop with the old ReadyNAS remote client still chugs away reliably - I would love to find a solution
- FramerVNETGEAR Employee Retired
Hi webZplus,
I apologize about the issues that you have encountered throughout the year.
May I ask about the status on the clout tab? There should be information about the "Internet" and "Services"; are they showing as available with green checks?
If not, kindly try setting up a static DNS on the ReadyNAS.
How do I configure DNS information for an ethernet interface on my ReadyNAS OS 6 storage system?
Hi webZplus,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Regards,Hello FramerV
On the Cloud Tab, both the Internet Available and Services Available have ticks, also the ReadyCloud 'switch' is on, the Proxy and Security settings are blank with the exception of a tick in the 'Encryption' box.
It would be great to resolve this issue as it has gone on far too long.
Cheers
Hi webZplus,
Are you already using the latest firmware for the ReadyNAS?
ReadyNAS OS 6 Software Version 6.6.1
