McRob1's avatar
McRob1
Luminary
Feb 14, 2017
ReadyCLOUD not connecting
I have been trying to get readycloud working on a ReadyNAS Pro 6.  It is running firmware version 6.6.1.
The readycloud desktop application shows it as offline.
When I go to to the cloud tab and turn on readycloud the button toggles on for a few seconds to on and then turns itself back off again.
I am not sure if my readycloud account is messed up becasue I upgraded the firmware on this unit from 4.1.30 to 6.6.1 or it's something else.
Any suggestions would be appreciated to get this working.
Thanks
  • This has now been fixed. The correct serial number is now programmed in and an issue with the ReadyCLOUD admin user's group membership has also been fixed.
  • A little more information:
    The services available and the Internet available green check marks to show up sometimes.  But the on/off button always switches back to off by itself.
    The readycloud desktop application does see the readynas because it shows it as offline.
    Under Cloud if I click on the blue text ReadyCloud it takes me to the Netgear signin page.  I can sign in and the nas shows up as off line.
    If I go to discover and then select manage it does take me to the admin page of the local NAS.
    • McRob1's avatar
      McRob1
      Luminary
      Looking thru the logs I found this entry over and over again.
      It appears that the NAS is not working correctly.
      cloud_get_owner.c:126 rnobj_getUserCollection() *userid=-1 username=***********@comcast.net error=`Undefined error from rnobj`
      I wish that someone would respond to my questions so I could try something to get this working.
      • mdgm-ntgr's avatar
        mdgm-ntgr
        NETGEAR Employee Retired
        Can you send me your logs (see the Sending Logs link in my sig)?
  • Sandshark's avatar
    Sandshark
    Sensei - Experienced User
    If that is your only NAS, then you did not have a ReadyCloud account, you had a ReadyNAS Remote one -- they are not the same.  OS4.x does not support ReadyCloud and 6.6.x does not support ReadyNAS Remote.
    • McRob1's avatar
      McRob1
      Luminary
      I have two other NAS's that I am running readycloud on.  They work fine.
      The interesting thing is readycloud desktop reconizes the readynas pro, it shows offline.
      I also have a old Readynas NV that I use readynas remote with.  OS 4.1.15.
        mdgm-ntgr
        I've identified the problem. I've sent you a PM.
ProSupport for Business
