Popsicle's avatar
Popsicle
RN102 currently you have no registered devices
Hi Guys,
My readycloud PC client tells me "currently you have no registered devices" even though it was working before. It also throws the following error:
What should I do to fix my client?
Thanks,
Popsicle
  • Retired_Member's avatar
    Retired_Member
    Hello Popsicle
    looks like something in your ReadyCLOUD client is broken,please uninstall/install it again from following link
    Windows version
    http://readycloud.netgear.com/client/install/ReadyCloudSetup.exe
    Mac version
    http://readycloud.netgear.com/client/install/ReadyCLOUD.pkg
    Please make sure that there is no update package in users folder.
    On MAC:check and  remove file / Users/[logged in user]/Library/Application Support/ReadyCLOUD/ReadyCLOUD.pkg.version
    On windows:check and remove file C:\Users\[logged in]\AppData\Local\Temp\ReadyCloudSetup.exe
    • CIWY's avatar
      CIWY
      Tutor
      I've got the same problem, but on Mac.
      I had normal access, without a problem, but suddenly the message that I don't have any connected devices appears. I tried to deinstall now, but it doesn't even deinstall.
      • JennC's avatar
        JennC
        NETGEAR Employee Retired
        Hello Popsicle and CIWY,
        Also, does it work when you log in via ReadyCloud portal instead of the desktop client?
    • Popsicle's avatar
      Popsicle
      Hi Guys,
      Thanks for all the helpfull feedback, I really appreciate it!
      Reinstalling did the trick for now.
      • FramerV's avatar
        FramerV
        Hi Popsicle,
        If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
        The Netgear community looks forward to hearing from you and being a helpful resource in the future!
ProSupport for Business
