davesumm's avatar
davesumm
Luminary
May 24, 2017
VPN Disconnected as of 2017-05-25
I'm currently Online (VPN disconnected) again. Is this an anomaly or is there yet another Netgear fail?
  • Turns out all i needed to do was restart the desktop client :P
  • Retired_Member's avatar
    Retired_Member
    Hello Davesumm
    can you please check if Leaf network interface of your Windows has obtained IP address from server?you can go to Network and Sharing Center>Change Adapter Setting>Leaf  Networks Adapter>Details,correct IP should be 5.*.*.*,have you installed any firewall application on your Windows?
    • davesumm's avatar
      davesumm
      Luminary
      I have an IP address beginning with 5 and no, I haven't installed any firewall. Was working fine earlier and now it's gone **bleep**-up
        Retired_Member
        Can you reboot the NAS?I just connect to  my NAS and able to  get VPN connection
ProSupport for Business
