cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- mdgm-ntgrNETGEAR Employee RetiredLater first-gen Pro units might have stronger similarities with the Pro 6 than earlier first-gen Pro units.
The Pro 6 has a faster CPU than the Pro and some other newer hardware necessary to support that. So if you want to upgrade the CPU (voids warranty) you'll be able to upgrade to a faster CPU in the Pro 6 than you could in the Pro.
Support should've been better informed than that. The compatibility list is still there for the first-gen Pro: http://kb.netgear.com/app/answers/detail/a_id/20641
The Pro Business Edition is e.g. the RNDP6000-100 whereas the Pro Pioneer Edition is the RNDP600E-100. When the system is running you should see in Frontview and in RAIDar which you have as well. - CompuTutorAspirantAhhh, I see, and TY MDGM.
So it is just a naming-convention thing.
I'll check FrontView/RAIDar tomorrow when I wake.
Thank you so very much for assistance in properly populating it
with the correct and tested HDD's for it.
Yes, at least three people answering their (support) phone's SHOULD have known better. :)
The question still stands about the buss speed,
why buy SATA-300's for a SATA-150 buss I mean.
Any easy way to confirm this pre-teardown ?
(Sorry for OT side question people, I'll make up for it...)
EDIT:
Wow, I KNOW my device can't be SATA-600,
this seems like a waste to get this capacity:
Hitachi 3-TB 6Gb/s 64-MB - Ultrastar 7K3000 HUA723030ALA640
Seagate 3-TB 6Gb/s 64-MB - Constellation ST33000650NS
Seagate 3-TB 6Gb/s 64-MB - Barracuda XT ST33000651AS - mdgm-ntgrNETGEAR Employee RetiredWell I think SATA II (3Gbit/s) hard disks wouldn't even saturate SATA I (1.5Gbit/s) anyway. However over time improvements to speeds of disks are made. Each generation should be faster than the previous one (obviously you have to compare similar disks). So the SATA II (3Gbit/s) disks would probably be a bit faster than the 1.5Gbit/s ones (which would be older). Likewise for SATA III (6Gbit/s) vs SATA II (3 Gbit/s). The first-gen Pro does have SATA II (3Gbit/s) ports. It will work with SATA III (6Gbit/s drives) but at SATA II (3Gbit/s) speeds (not that a SATA III HDD would be expected to saturate a SATA II connection anyway).
Different users have different needs. Choose the capacity that's right for you.
Currently I have 6x1.5TB disks and I'm using X-RAID2 dual-redundancy which gives me about 5.4TB of space. - CompuTutorAspirant
It isn't a capacity issue, SATA-300 devices are reverse-compatible with SATA150 busses,
but sadly (Confirmed on many tech sites) SATA-600 drives flubble on SATA-150 busses,
they reverse-comply often to unrealistic buss speeeds sadly, and suffer
(NetGear COULD firmware this problem a bit though / retain SATA-300 speed).
Not a good idea on a RAID-Enabled network solution,
as people have refered to this list with failure !
They are designed to, and mean to play on them,
but are proving to be oddly slow compared to native drives.
(I suspect architecture compliance, and an algorithm issue).
The very fact that (again, not a max addressability issue)
there is no build-specific way to address critical update data
So knowing the interface is much more important then selecting capacity overall.
Lets face it, older drives speaking (what was) current speak-ology
work best on their current adddressabilty and their legacy buss.
I (only) know some 2-TB drives listed (Business Edition )are received well without issues,
and 3-TB platters seem fine when introduced, but fail upon filling them above ~1.85-TB.mdgm wrote:
Is your device a native -100 or -200 device please ?
(Sorry, reading a day or two would yield this info too...)
Again, I wanted someone to reply with confirmed 2-TB drives,
as most 3-TB are to far ahead the spec-wavr for a -100 unit.
But that they (NetGear) transitioned poorly with mixed hardware content
(like my -100 board with newer 16-pin VGA ports, and additional jacks)
makes my newest/bestist HDD not such a clear path for me...
Is that (Pro Business) list for a board with (ancient) 12-pin VGA ports,
or my transitional 16 -1 pinout later board that was re-firmware'd -200 ?
This has been one of the weakest points in the release of all these models,
and I am now sure the "Scripted" info (from the board manufacture) is in error
for the staff that answer the support phone daily sadly.
Most other manufacturers of computer product in the consumer division
are at least database'd into "build's" by exact serial number to prevent the
downloading of incorrect drivers and introduction of incompatible hardware.
This leaves me back at the point I was trying to make.
No one can tell me what I have, even the re-distibuter (NetGear)
of a device that is clearly made outside of our country (USA)
then sold in the USA causing these support staff being uninformed.
This seems like a rant, and possibly anti-NetGear in basis,
but I feel bad for the support staff that has no idead what
what we were shipped to all of us by the retail re-sellers.
As emaple (All I want is):
1 - What exact board (maker/model) do I own,
what is the maximum bios level for the model tier ?
2 - what is the exact data/app-load on this system ?
3 - What exact HCL (as they put different MB in the -100 line...) do I use ?
3 - how can they (during warranty calls) determine if parts are available ?
There are many more questions,
but those are core questions asked,
and are never NetGear answered due to
being (propritoty) info (they say....
I'll rip it apart, I'll know with certainty,
but this IS NOT the consumers job,
only a serial should be needed. - mdgm-ntgrNETGEAR Employee Retired
It isn't a capacity issue, SATA-300 device are reverse-compatible with SATA150 busses,
Where did you read this? Can you give a link? I've heard of issues with some SSDs (not supported in the ReadyNAS) but haven't heard of this issue with hard drives.CompuTutor wrote:
Your NAS would have SATA II (3Gbit/s) anyway so this is a non-issue for you but unless a hard drive is pushing 150MB/s it's not going to saturate SATA 1 (1.5Gbit/s) let alone SATA II.CompuTutor wrote:
Lets face it, older drives speaking (what was) current speak-ology work best on a buss.
I don't think the SATA connection speed is the limiting factor here. Remember a gigabit connection will push up to about 100MB/s or 200MB/s if you team the NICs, but the CPU would limit it to below that speed. The RAID array is going to be faster than what you can push down your network. I think you're worrying a lot about something that really isn't very important.CompuTutor wrote:
I (only) know some 2-TB drives listed (Pro 6 )are received well without issues,
and 3-TB platters seem fine when introduced, but fail upon filling them above 1.85-TB.
NetGear performs a number of rigorous tests on hard drives to qualify them. The 4.2.16 update added support for 3TB disks. 3TB disks on the list work fine.CompuTutor wrote: mdgm wrote:
I have a RNDU6000-100 (ReadyNAS Ultra 6 Diskless). This has SATA II ports.CompuTutor wrote:
The -100 indicates it's a first gen Pro. The second gen Pro, the Pro 6 has a faster CPU. It says nothing about the SATA speed. All ReadyNAS Pro units have SATA II (3Gbit/s) ports.CompuTutor wrote:
NetGear would test a representative selection of units of each model to make sure that drives that are qualified work with all units of a model.CompuTutor wrote:
It should be clear from the label on the unit and from what you see in RAIDar and Frontview which you have.CompuTutor wrote:
The differences apart from the CPU in the two models aren't really that important to probably 99.9% of end users.CompuTutor wrote:
are at least database'd into "build's" byexact serial number to prevent the
The firmware for all x86 ReadyNAS units is the same. The drivers for different hardware in different models is included in the firmware.CompuTutor wrote:
They should be able to tell from your serial number whether you have a first-gen or second-gen Pro but you should be able to check that yourself too.CompuTutor wrote:
Most people don't want to know the level of info you are after. Knowing which model you have is generally enough.CompuTutor wrote:
The board may vary depending on when the unit was built and what boards NetGear had at the time.CompuTutor wrote:
That depends whether you have a first-gen Pro or a second-gen Pro. Different boards and different BIOS.CompuTutor wrote:
If you have the Pro BE (e.g. RNDP6000-100) then use that list. If you have the Pioneer (has E in the model number i.e. RNDP600E-100) then use the compatibility list for that.CompuTutor wrote:
NetGear can replace the unit via RMA if there is hardware failure covered by the warranty.CompuTutor wrote:
As the internals in the unit are really of no concern to end-users apart from the specs provided there's no need to know in depth what the internal specs are of the unit though you can easily find out by opening up the unit and investigating for yourself if you're really interested. - beisser1Tutorjust for info im running this baby on my pro: http://ark.intel.com/products/27205/Int ... 66-MHz-FSB basically nothing more than a glorified E6400 :)
CompuTutor wrote: Westyfield2 wrote:
"So on the ‘new’ Pro 6 (RNDP6000-200) the motherboard VGA header is in fact a 15pin connector,
not a 12pin connector like the old one had."
I am the new owner of a RNDP6xxx-100NAS,
and I DO have the 15 (16 -1-Plugged) pinout.
Were -100's shipped with the 12-pin pinout too ?
Apologies for the confusion. I haven't seen inside an old one, everything I'd read online had just referred to the 12-pin header so when I opened my new Pro 6 (RNDP6000-200) and saw the 15-pin header I just assumed it was old vs new Pro difference.- marcuspTutor
Westyfield2 wrote:
The bit that mentioned “Broadwater” intrigued me, as that’s not AMI’s address! Broadwater was the Intel codename for the P965/G965/Q965 chipsets. Now that could of-course be wrong, but lspci reckons it's an Q963/Q965 chipset too. In the previous post http://www.readynas.com/forum/viewtopic.php?f=35&t=29284&start=90#p367951 we listed the Chipsets and what CPUs Intel say are compatible, so adding these possibilities to the list gives:- For the Q963 Intel list only the E6700 - so if this is the chipset surely the Q6700 and E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the P965 Intel list the E6700 and Q6700 - so if this is the chipset surely the E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the G965 Intel list the E6700 and Q6700 - so if this is the chipset surely the E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the Q965 Intel list only the E6700 - so if this is the chipset surely the Q6700 and E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the DP965 Intel list the E6700 and Q6700 - so if this is the chipset surely the E7400 shouldn't have worked? And the Pentium D E5300 that Netgear are fitting isn't on the list!
- For the G31 Intel list the E5300, the E6700, the Q6700, and the E7400.
If you watch the video in this review, maybe it'll help you :) ! The guy removed everything in the nas, even each part of the mobo.
http://www.decryptedtech.com/storage-and-networking/netgears-readynas-pro-6-looks-like-a-pc-inside-a-nas-body/Page-3 - Hmm, so he reckons it's a 965. I did LOL at it though, he reads out the processor as Pentium E5388... which doesn't exist. It's a Pentium E5300, but the slashed zeros must have confused him :p.
In other news, I found a C2D E7600 cheap and stuck it in a Pro 6. Works fine :). - chirpaLuminaryI thought the same thing over the E5800 heh. I'm running an E6400 right now with no issues.
