cpitchford
May 22, 2009Guide
More on CPU specs of the ReadyNAS Pro
Hi all,
Does anyone know what FSB speeds the ReadyNAS Pro motherboard supports.
I have three "servers" that I'm trying to consolidate. I figured that the file server (which is actually the slowest machine) would be replaced by the NAS but I'm actually trying to merge some other services onto the box which much luck so far..
One feature I'm working on porting is my Tivo transcoder. Essentially I have a small system that pulls programs off my Tivo, transcodes them and uploads (via WiFi/ethernet) to my portable media player. It means when I get home my media player syncs with my now-playing list so I can watch TV on the train too and from work. Since I work miles and miles away, I don't have time to watch TV at home so it's the only way I can watch TV..
I have the package working on the NAS, and I'm working on the integration with the front end (like managing black-lists and so on). I'd like to bump the speed of the processor but obivously the newer energy efficient <65W intel chips all seem to be 1333MHz FSB. Is this supported on this NAS? I know the warranty is void with this type of fiddling, but that is a risk I'm happy to take.. I also understand you wouldn't recommend an upgrade like this, but I would really like to know if it were possible..
I'll make all the code (mplayer is the driver behind the transcoding) available to anyone if interested.. but it is important to realise this is a Series 1 Tivo and an Archos 705/605 media player, not a common combination..
- jakkesAspirantWould this cpu work in a readynas pro:
Intel Boxed Intel Pentium Dual-Core ProcessorE6700 ( 2MB Cache 3.33 GHz 1066 MHz FSB)2 cores & 2 threads. LGA775
Or this one:
Intel Boxed Intel Pentium Dual-Core ProcessorE6700 (2MB Cache 3.20 GHz 1066 MHz FSB)2cores & 2 threads. LGA775 - WhoCares_MentorNope, tested both of them. Neither works ;)
-Stefan - jakkesAspirantDid you find a cpu that did work?
- WhoCares_Mentor
jakkes wrote: Did you find a cpu that did work?
Core2 E6600 & E6700 (why Intel did re-use these numbers for the Dual-Core Pentium, I'll never understand).
On Intel's site, look up the DP965/967 Chipset specs. There should be a list of compatible CPUs (at least there was last time I looked).
-Stefan - jakkesAspirantok, thanks for the tip.
Now trying to get a cpu.... - Just installed a Core 2 Duo E6700 with a Silverstone FM83 fan on Readynas Pro Pioneer
http://www.silverstonetek.com/products/p_contents.php?pno=fm83
Some slight tinkering is necessary to make the fan fit as it is so tall that it touches the side panel, but everything seems to be running fine. I do hope the increased power of the fan (it is actually a 92mm fan in a 80mm frame, with up to 72 CFM) offsets the increase in power of the CPU.
I have a question:
Is it possible to control the minimum/maximum fan RPM in the Pro? I have seen an add-on for this but it is only for Sparc. - jmirabilAspirantDoes an E8600 work? Alot of power but should run cooler than an E6600.
Anyone try an E8600 in a readynas pro? - xtrips1AspirantHello
Who here can claim having performed the best Readynas Pro upgrade (cpu and memory)?
By best I mean of course most performance gain without stability issues.
I want to do the same but I'd rather rely on my most experienced peers.
Thank you - I have received some private queries on the performance of my Readynas Pro Pioneer after upgrading it to an E6700 CPU. I post here to benefit everybody.
The upgraded Cpu has been in place for 9 months with no issues that I can see. I had a scare after upgrading the unit to 4.2.18 a few days ago because the unit suddenly locked up and refused to boot. But the problem went away after a few reboot attempts and an fs check, so I'm inclined to think that it was a glitch with the upgrade.
I also increased memory to 4GB a while ago.
Which upgrade gives more performance increase? I think the CPU upgrade is worthwhile for me because I manage a big share with a lot of large files (my DVD collection actually), so I do benefit from the added power when it comes to fs scans and rsync backups. I haven't tried video transcoding yet but I hope it will be an advantage there too... your mileage may vary.
I installed a big fan along with the new CPU, but I'm thinking that maybe it is not necessary. The Stock fan is probably enough to cool it. The fan rpms will be higher on average though. The advantage of my big fan is that it can do effective cooling while being reasonably quiet. Actually my Pro Pioneer seems to be a lot quieter than The Ultra 6 I have as a backup unit.
Hope this helps... - xtrips1AspirantThanks for sharing.
So to sum up, I can go for a E6700 and 4Gb of ram without worries.
I still have some more questions though.
Is that compatible with my Readynas Pro (not Pioneer)?
I suppose the 4Gb ram are 2x2Gb DDR2, but what kind? I mean the laptop kind or PC kind? What speed?
Is the access ti the mobo easy? Maybe screenshots or a Youtube howto is available?
Thx
