WhoCares_'s avatar
WhoCares_
Mentor
Jul 17, 2012
OwnCloud 8.0.4
ownCloud[/sizde]
    • Description
      ownCloud> is a flexible, open source file sync and share solution. Whether using a mobile device, a workstation, or a web client, ownCloud provides the ability to put the right files at the user's fingertips on any device in one simple-to-use, secure, private and controlled solution.
    • Requirements:
        • ReadyNAS Platform: ARM
      • ReadyNAS Firmware: RAIDiator 5.3.5 or newer
    • Requires:
      • PHP 5.4: For this add-on to work, the PHP 5.4 add-on has to be installed first!
  • Configuration
    After installation of the add-on, open the add-on's pane from the list of installed add-ons and click on the "Access you ownCloud" link. You will be redirected to your ownCloud installation.
    if you're asked to login, use admin as your username. The default password after initial installation is netgear1.
    For further configuration options please consult the OwnCloud Online Documentation.
  • Thanks so much for building/maintaining these addons!
    Any chance on getting us to an updated v9 anytime soon? Would be greatly appreciated. . .
  • Ok. I have gone to rnxtras and purchased the latest update. I won;t install neither will the previous v6? Any help appreciated otherwise sorely disappointed.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      For the RN104 you need apps for ReadyNAS OS6 (ARM). The OwnCloud app is the one deb for both platforms.
      Which firmware are you running? Do you have any other apps installed? Have you tried reaching out to RNXtras/WhoCares? for assistance?
      • agoodside's avatar
        agoodside
        Hi mdgm,
        thanks for the reply. It's a Radynas 104 OS 6.51 (arm).
        No other apps. I went onto the RNxtras website but there is no conatct or support option.....
  • I am fairly new to ReadyNASand am running an RN202 with OS 6.5.1.  I have seen the OwnCloud app in the Netgear app store but admittedly am confused why I would need this.  Isn't one of the reasons to have a ReadyNAS is to have your own cloud services?  I did look at the OwnCloud site and there appears to be a lot of apps available but on a basic level, could you explain why someone would use OwnCloud vs. just the readyNAS if all they want is remote access to their files?
    Thanks,
    David
    • StephenB's avatar
      If all you want is remote access, then you have basically two alternatives
      -use port forwarding for ftps (or https) combined with ddns
      -use OpenVPN combined with ddns
      You can also use a variety of other tools that have additional features - generally sync and controlled sharing
      -ReadyCloud
      -OwnCloud
      -Bittorent Sync
      -Amazon Cloud sync
      -plex (limited to media)
      You can learn more about the OwnCloud features here: https://owncloud.org/features/
      Personally I use OpenVPN for general remote access - that runs in my R8500 router.  Clients are installed on my mobile devices and laptop.
      I've been playing with Bittorrent sync for some folders - one benefit is that it will transfer files in the background.  I'm not running it on my NAS though - I run it on a PC (with the NAS mapped to a drive letter).
      I also use plex, and allow family members access to my media.
      • dschwartzer's avatar
        dschwartzer
        Luminary
        StephenB:
        Thanks for the quick response.  I am already using Plex for media sharing.  I guess my question really is, what are the advantages of OwnCloud vs. ReadyCloud?
        David
    • WhoCares_'s avatar
      WhoCares_
      Mentor
      Yup, got it. To me it looks like the OS partition of your ReadyNAS has run out of space. Can you please check by running "df -kh" in an ssh shell?
      -Stefan
  • here it is:
    Welcome to ReadyNASOS 6.6.0
    Last login: Fri Dec 30 16:28:04 2016 from 192.168.0.110
    root@NASPON:~# df -kh
    Filesystem      Size  Used Avail Use% Mounted on
    udev             10M  4.0K   10M   1% /dev
    /dev/md0        4.0G 1010M  2.8G  27% /
    tmpfs           249M  4.0K  249M   1% /dev/shm
    tmpfs           249M  476K  248M   1% /run
    tmpfs           125M     0  125M   0% /run/lock
    tmpfs           249M     0  249M   0% /sys/fs/cgroup
    /dev/md127      2.8T  971G  1.8T  35% /data
    /dev/md127      2.8T  971G  1.8T  35% /home
    /dev/md127      2.8T  971G  1.8T  35% /apps
    it would be strange for me that there is no space. i do not have installed any app.
    • FramerV's avatar
      FramerV
      Hi osilvab,
      Does seem that you have space on your OS partition. Let's wait for a feedback from WhoCares_.
  • I have tried differnt things but no luck yet.
    here is the log:
    START(/tmp/C:\Users\osilv\Downloads\owncloud_9.1.1-rnx1_all.deb): Tue Jan 3 10:05:32 CET 2017
    Ign http://dl.bintray.com wheezy InRelease
    Get:1 http://dl.bintray.com wheezy Release.gpg [821 B]
    Hit http://security.debian.org jessie/updates InRelease
    Hit http://egnyte-cdn.egnyte.com 6.6 InRelease
    Get:2 http://dl.bintray.com wheezy Release [1,839 B]
    Hit http://apt.readynas.com 6.6.0 InRelease
    Hit http://security.debian.org jessie/updates/main armel Packages
    Hit http://egnyte-cdn.egnyte.com 6.6/egnyte armel Packages
    Hit http://security.debian.org jessie/updates/main armhf Packages
    Hit http://egnyte-cdn.egnyte.com 6.6/egnyte armhf Packages
    Get:3 http://apt.readynas.com 6.6.0/updates armel Packages [2,197 B]
    Get:4 http://apt.readynas.com 6.6.0/apps armel Packages [32.5 kB]
    Get:5 http://apt.readynas.com 6.6.0/main armel Packages [149 kB]
    Ign http://mirrors.kernel.org jessie InRelease
    Hit http://mirrors.kernel.org jessie Release.gpg
    Get:6 http://apt.readynas.com 6.6.0/updates armhf Packages [520 B]
    Get:7 http://apt.readynas.com 6.6.0/apps armhf Packages [21.8 kB]
    Get:8 http://apt.readynas.com 6.6.0/main armhf Packages [56.1 kB]
    Hit http://mirrors.kernel.org jessie/main armel Packages
    Hit http://mirrors.kernel.org jessie/main armhf Packages
    Fetched 265 kB in 18s (14.6 kB/s)
    Reading package lists...
    Building dependency tree...
    Reading state information...
    0 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
    fv-dpkginstall.awk: error 0
    Successfully installed dependencies for /tmp/C:\Users\osilv\Downloads\owncloud_9.1.1-rnx1_all.deb
    dpkg: error processing archive /tmp/C:UsersosilvDownloadsowncloud_9.1.1-rnx1_all.deb (--install):
    cannot access archive: No such file or directory
    Errors were encountered while processing:
    DONE(5): Tue Jan 3 10:06:17 CET 2017
    spooler returns spool_status=5 outbuf=(null) errbuf=(null) is_localapp=1 name=C:\Users\osilv\Downloads\owncloud_9.1.1-rnx1_all.deb pkgname=owncloud
    any other help??
  • I have tried differnt things but still no luck.
    I can not post the log here becasue then its filtered as spam :smileyfrustrated:
    if someone else can help me i can send it by PM
      WhoCares_
      Mentor
      You can send it to info@rnxtras.com if you want.
      -Stefan
  • whocares assisted me. the problem seem to be related to the broswer i was using (edge) as soon as I try another one it worked perfectly.
      WhoCares_
      Mentor
      Note to moderators: As it seems Edge is sending not just the filename but the complete path instead when uploading a file. So instead of receiving for example "owncloud_9.1.3-rnx1_all.deb" the ReadyNAS will get a filename like "C:\Users\username\Downloads\owncloud_9.1.3-rnx1_all.deb". This will make the install procedure fail when trying to actually install the package using dpkg. Solution for now is to recommend using a different browser to the users, a better solution would be to find a workaround that can be implemented server side.
      -Stefan
ProSupport for Business
