bettley_smith
Jun 28, 2011Aspirant
Remote Upload
Am I going wrong?, I can use the remote email to upload pictures and they appear, when I try the FTP upload, i can see then in the upload folder but they do not transfer to my Readynas Album.
Darth_Vader
Jul 22, 2011NETGEAR Employee Retired
viperhansa wrote:
bettley-smith wrote: Just moved to version 1.0.2, now get some problems listed and when i diagnose get this:
OK: All connection tests from ReadyNAS Photos II to UPnP Router and photos.readynas.com site are passed.
OK: Hostname BettleySmith is available.
Error: Fail to access Photos II (http://78.149.xxx.xxx:8086) from internet. (error=-1).
OK: Successfully found your public IP (78.149.xxx.xxx).
(xxx) to hide identity
What does this mean?
Same here after update to 1.0.2.
1.0.1 worked good, except ftp uploads.
Can you check if your port number has been changed? No longer using 8086?
Thanks
