bettley_smith
Jun 28, 2011Aspirant
Remote Upload
Am I going wrong?, I can use the remote email to upload pictures and they appear, when I try the FTP upload, i can see then in the upload folder but they do not transfer to my Readynas Album.
w00dy
Sep 06, 2011Aspirant
Hi,
RE:
I seem to have exactly the same problem. I have an ultra 4 sitting behind a DLINK upnp router/firewall; just tried to use ReadNAS photos II for first time and get same problem as above (RAIDiator 4.2.17; photos v1.02). Have been running for a while with my ReadyNAS accessible to internet via webDAV over SSL so i know i can get through the firewall to the ReadyNAS on the IP address - but seem to get absolutely nothing there when try to access port 8086... tried from inside and outside firewall using both internal and external ip addresses... any ideas anyone? Thanks.
RE:
bettley-smith wrote: Just moved to version 1.0.2, now get some problems listed and when i diagnose get this:
OK: All connection tests from ReadyNAS Photos II to UPnP Router and photos.readynas.com site are passed.
OK: Hostname BettleySmith is available.
Error: Fail to access Photos II (http://78.149.xxx.xxx:8086) from internet. (error=-1).
OK: Successfully found your public IP (78.149.xxx.xxx).
(xxx) to hide identity
What does this mean?
