Calder
Jan 18, 2017Guide
6.6.1 did not fix UPS detection problem
Still needed to unplug and re-plug USB cable to UPS after a restart for UPS to be detected.
Wed Jan 18 2017 16:51:20
System: New USB UPS detected. Manufacturer: APC, Model: Back-UPS ES 550G, Serial: 4B1421P42699.
Wed Jan 18 2017 16:51:15
System: USB UPS removed. Manufacturer: , Model: , Serial: 4B1421P42699.
Wed Jan 18 2017 16:50:49
System: Cannot communicate with UPS UPS ().
Wed Jan 18 2017 16:50:36
System: Error communicating with UPS 'UPS' ().
Wed Jan 18 2017 16:49:15
System: Firmware was upgraded to 6.6.1.
System: ReadyNASOS background service started.
Wed Jan 18 2017 16:42:14
System: The system is rebooting.
- mdgm-ntgrNETGEAR Employee Retired
So you started seeing this on 6.6.0?
Can you send in a fresh set of logs (see the Sending Logs link in my sig)?- CalderGuide
Started seeing since probably 6.2, not sure how I coiuld search my previous posts in the forum, been having this problem for a few updates now. Logs sent. Thanks!
- gyves1Luminary
I confirm the issue, I receive often an alert by email about UPS loose connection and then a new UPS found.
It's an old issue but stil present FW 6.6.1
- JanHussaarts2Luminary
I'm running 6.6.1 on an Ultra 6. No problems with my APS Smart UPS 1000
Your logs show that your UPS is detected fine.
