hunger
Jan 08, 2016Apprentice
8 TB HDD
I noticed that there are no 8 TB disks on the hardware compatibility list, even though 8 TB enterprise disks have been available for some time now and the specs for the RN3138 say that the maximum ca...
- Mar 27, 2016
I have installed four Seagate ST8000VN0002 drives in my RN3130 and they appears to be working just fine. It took about an average of 12 hours per drive, plus an additional 12 hours at the end to create the new space.
I started the process Wed Mar 16 2016 0:59:03 and, with interruptions, finished Sat Mar 19 2016 0:45:33.
hunger
Jan 16, 2016Apprentice
The ST8000NE0001 is out of stock at all of my usual suppliers. Should be back in stock at the end of the month. I'll check again then.
BrianL2
Jan 16, 2016NETGEAR Employee Retired
Hi hunger,
Thanks for posting feedback on this thread. I have added a kudos to the topic that you've posted in the idea exchange board. Hopefully, soon you can order the 8TB drive that you need :)
Kind regards,
BrianL
NETGEAR Community Team
