hunger
Jan 08, 2016Apprentice
8 TB HDD
I noticed that there are no 8 TB disks on the hardware compatibility list, even though 8 TB enterprise disks have been available for some time now and the specs for the RN3138 say that the maximum ca...
- Mar 27, 2016
I have installed four Seagate ST8000VN0002 drives in my RN3130 and they appears to be working just fine. It took about an average of 12 hours per drive, plus an additional 12 hours at the end to create the new space.
I started the process Wed Mar 16 2016 0:59:03 and, with interruptions, finished Sat Mar 19 2016 0:45:33.
hunger
Mar 27, 2016Apprentice
- BrianL2Mar 28, 2016NETGEAR Employee Retired
Hi hunger,
Thanks for posting back. It appears that you have successfully installed four 8TB hard drives on your ReadyNAS RN3130 system. We're glad that it worked and didn't cause you any problem. You may continue to post feedback about your system or if all is set, this thread can be mark closed.
Kind regards,
BrianL
NETGEAR Community Team
