eclark
Apr 27, 2016Aspirant
Can I have two ReadyNas 316 (or another model) systems auto back up to one another?
Hi!
I am a professional photographer and we are looking for a streamlined solution for our photo and video backup. I would like to have one ReadyNas system at my studio and then have it both back up to the cloud and to a second system at my house. Is that possible?
It is possible. You can use replicate to back up to the system at your house.
There are a couple of options to back up to the cloud. What make sense there depends on what cloud service you are talking about. I use crashplan on my pro-6 - that needs to be manually installed with ssh and requires some linux knowledge. Though you can alternatively install crashplan on a windows-10 system, and mount the NAS volume as a network drive - backing up the NAS through the windows 10 system.
Amazon Cloud sync is in beta, I am not sure if it is ready to do what you want yet.
You could also use Egnyte, you'd need to contact them for pricing. But it looks like you'd get 10 TB of cloud storage with a single-employee license for $15 per month.
- JennCNETGEAR Employee Retired
Hello eclark,
Welcome to the community!
There are 2 options, backing up using rsync protocol which backs up one system to another locally or the ReadyNAS Replicate that needs Internet.
Here are the article you may want to see and read:
How do I back up data between two ReadyNAS OS 6 systems (using the backup manager)?
How do I back up data between two ReadyNAS OS 6 systems (using ReadyNAS Replicate)?
Hello eclark,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accept as Solution” so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
- SandsharkSensei
If your intent is that the contents of the two NASes will be the exactly same, then Replicate is not your answer. Though they call it "Replicate", it doesn't truly replicate; it's a backup and versioning system. Not that that's "bad", it's just not true replication. The backup files do not go into the same directory structure on the backup as on the source. If your primary system dies, you can buy a new one and restore from your backup. But you can't rename the backup machine and have it take over from the primary.
And if you will be adding and deleting or changing files on both NASes, I don't think there's a good solution, either. If you use RSync and set it to delete files on the target that have been deleted on the source, it's also going to delete any files you added to the target but not the source. Likewise, if you delete files from the target or modify them there, it's going to put them back from the source. So, you can only have one primary and one backup system, not a two-way cloning. If you use something other than RSync, it won't delete files on the target that have been deleted on the source.
I tried to figure out a way to use a combination of methods to produce cloning when files are being changed on both systems, and could't do it. Robocopy via a Windows computer or some other third party sync method was the only way I could see to do it.
Sandshark wrote:
And if you will be adding and deleting or changing files on both NASes, I don't think there's a good solution, either. ...
Sync is different from straight backup, and I agree there's no good solution with the built-in tools.
I think BT Sync would do it, but I haven't tried the app on the NAS yet. In my testing so far I'm using it on a PC and my two mobile devices (with the NAS mounted as a network drive).
But you might want to limit the Sync to a couple of working folders. The indexing can take quite a while
