mrhoads's avatar
mrhoads
Can not check for update
"Check for update" doesn't work. I have clicked on it many times and waited overnight but nothing happens. I got an email with the directions and that I needed to update but no luck. :oops:
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    What version of RAIDiator and what web browser are you using?
    Have you tried clearing your web browser cache?
    Have you checked that your settings under Network in Frontview are correct? Particularly you should check the DNS and Gateway settings.
    4.3 Can not download the new version.
    Yes
    All looks ok.
ProSupport for Business
