b4ndit90's avatar
b4ndit90
cant install system
Hi all today i buy from second hand RNAS RND4000 v2. and i have problem with this machine. When i start without HDD i can go to admin padge. when RNAS connect to router.
When i plug in my hdd form my pc 2 TB i see rnas booting and after ERR:could no mount root .... and stop. i never have that staff and maybe i dont know how to install but i try all .. i make reset with clip from boot menu all and nothing work anybody can try help ?
  • StephenB's avatar
    Try unformatting the hard drive in the PC (use windows disk manager, and delete all the volumes).  Alternatively, zero the disk with the vendor tools (lifeguard for western digital, seatools for seagate).
    Then boot up the NAS with the disk inserted.
  • I suspect that you intended for all of the data on that drive to be available on the NAS, which is not what would have happened.  If so, you are lucky that nothing happened.  A NAS is not at all the same thing as a case for drives, like for USB.  It's a LINUX based server, and it needs to format it's disks in a LINUX compatible way.
    The NAS will not operate without any drives installed.  You need to install at least one drive and perform a factory default.  Note, again, that everything on that drive will be erased.
    • b4ndit90's avatar
      b4ndit90
      When i plug in new hdd form shoop i have msg Wating for RAID and time 10 min move down what next ?
      • b4ndit90's avatar
        b4ndit90
        I read in weeb i can plug in only
        NAS Optimised
        HDD .. did i can plud ing normal hhd from pc ? and some how setup then ? or only way buy
        WD Red xxxTB NAS Optimised 3.5 inch SATA III Hard Drive
ProSupport for Business
