PartialXRay
Sep 18, 2016Tutor
Corrupt boot - Factory Reset not working
Hi! I have a the RND2000v2 and it will not load. Using the most up to date version of RAIDar it tells me I have a Corrupt Boot. Following the manual I attempt to do do either a Factory Reset or a...
- Sep 19, 2016
Awesome information; So even though my model sticker on the bottom of it says RND2000 v2. It appears (at least according to the link you provided) to actually be a V1, this may be the issue at hand. I'll download the manuals for the v1 and see where tha gets me.
Sep 18, 2016Guru - Experienced User
Does RAIDar tell you "no disks" if you power up with no disks installed?
Also, if you have a Windows PC you should probably run the vendor disk diags (seatools for seagate, lifeguard for western digital),
