Chris_S's avatar
Chris_S
Dead Disk.. but not really
Does anybody have the same problem? So far this has happened twice to me:
brand new Ultra6. I get the message that Disk1 (also brand new, no SMART errors etc) is dead (out of 4 disks with dual redundancy Xraid2). I put in a replacement disk, nothing happens. No re-synching, on the webinterface, Disk1 still shows up as dead. I put back the original disk1 and reboot, everything is fine again. This has happened twice. My question: apart from why does a good disk show up as dead when it isn't, isn't the unit supposed to integrate the new (replacement) disk on the fly?
I am wondering if something is wrong the my chassis. Because:
about a week after I bought the unit and after running it on 3 disks, I put in a 4th one and then it crashed while re-synching. The unit would then not go properly into tech-support mode, only after several OS-reinstalls (basically, when in tech support mode it picked up an IP address outside my network!?). Netgear tech support eventually managed to get some of my data back (they too could not figure out what had happened in the first palce and/or why my unit would not go into tech support mode), but that took several weeks. In the meantime I tried to return the unit but the shop would not take it back because it's past the 2 week return period..
Thanks a lot!
ProSupport for Business
