  • StephenB's avatar
    ProsperoParisi wrote:
    Hi, I have 4 hard drives and a readynas rn31400, you can make 2 raid1?
    HD1+HD2= raid1-1 and hd3+hd4=raid1-2?
    Thank you
    Yes.  You'd switch to flexraid after the initial setup, and destroy the RAID-5 (xraid) volume.  There's no need to wait for the volume sync to complete.
    Then you can select the first two drives, and create a RAID-1 volume; and repeat that process with the second two drives.
    I suggest that you read through chapter 2 in the software manual first - http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
    • cpu8088's avatar
      cpu8088
      Virtuoso
      2 x raid 1 that would be 2 volumes/arrays of raid 1
      how about raid 10?
      • StephenB's avatar
        how about raid 10?
        Yes, that would be another option.
ProSupport for Business
