toonfan's avatar
toonfan
Follower
Oct 29, 2012
duo v2 help/advice needed
im new so first off sorry if im in the wrong place, i formatted my readynas duo v2 and ticked the delete volume(i think thats what it was called) on powering it up all im getting is the blue power light i have tried resetting it by using a paper clip and holding the power button until all the lights on the front are lit but when i press the backup button to select the boot order the lights go out and im left with just the power button lit,it was all working OK until i formatted the unit and ticked the erase volume i did read under the erase volume something about this will delete the drivers but thought when it was finished formatting it would auto install the drivers i have tried everything i know to get it to work,when i launch the raid utility its saying no drives/disks found when both bays have drives in them thanks in advance
1 Reply
  • StephenB's avatar
    Why did you think you needed to delete the volume??? You should have been finished when you "formatted" it (which initializes the RAID array).
    Erase volume takes quite a while (it does a secure erase).
    One option is to simply let it finish. Or you could attempt the factory default procedure again. The process is here: http://www.readynas.com/kb/faq/boot/how ... o_2_duo_v2
ProSupport for Business
