scion's avatar
scion
Fastest way to migrate DUO RND 2150?
My ReadyNAS DUO RND 2150 is RAID 1 and more than 3 years old. I'd like to create a separate backup and keep it offsite. Is there any easy way to 'duplicate' all its contents by migrating one disk to another NAS? If so, which unit is compatible?
If not, what is the fastest way to transfer about 500GB since USB 2.0 seems sooooo slow?
Thanks for any advice.
Ion
  • StephenB's avatar
    The NV+ V1 is also compatible. Though if you want to back up to another NAS, you should probably look at the ultra/pro or V2 platforms. The disks are not compatible, but the platforms are much faster.
    If you simply want to create a backup though, the fastest way to get 500 GBs copied is to do the backup over a gigabit ethernet connection to a PC. Transferring over the network to a USB 3.0 or eSata drive on the PC will give you ~25 MB/s throughput, and would take about 6 hours for 500 GB. You could update it using incremental copies (look into Robocopy).
  • Thanks Stephen
    Can I just double check my understanding: I can take a hard drive from my existing DUO RND 2150 and put it in a NV+ V1 along with a blank HDD and the NV+ V1 will copy the contents internally on the new blank drive.....? Cool, that sounds a lot faster than transfers over my LAN.
    Ion
  • Your only problem would be finding a good NV+ since they have been out of production for almost a year. There are still some left in spots in the retail market where they can be found, but at a high price. Used ones are plentiful on eBay. For the money, I agree with StephenB that you would be better off with an Ultra/Pro which is much faster. While it would require additional drives, once you had the data copied over, you could use the existing Duo (v1) to serve as a backup target for the new NAS. You could go with the new Duo v2, which is ARM based, and with the newer versions of Frontview supports the NFS/rsync backup routine to backup NAS to NAS. You can get a Duo v2 and two 1TB disks for less than I have seen of the older NV+ (v1) units listed. (And the new Duo is far faster).
    Edit Update: Corrected NV+ version in last line from (v2) to (v1). The NV+ v2 is the newer NV+ version and is written without () because the v2 is part of the name. To distinguish between the two, most members that post on the forum add the (v1) after the NV+ with () because it is not actually part of the original name.
ProSupport for Business
