sk92337
Aug 18, 2018Follower
Having problem moving folders to ReadyNAZ 214
Can some tell me how do I reach tech support for a ReadyNAZ 214? Made the purchase in June 2018 so I'm still under warranty but the Naz is not showing up under my account. When I try to re-register it tells me the device is already registered. As a result it wont allow me to reach them. Im having a problem moving folders over and sharing files that prompted me to try to reach them. This is so frustrating.
Any help would be appreciated!
1 Reply
- JohnCM_SNETGEAR Employee Retired
Hi sk92337,
Welcome to the community!
You may try reaching support on this link: https://www.netgear.com/support/contact.aspx. You can also PM me the serial number of the NAS so we can check the device registration.
May I also know the exact issue that you have on the NAS? Maybe we can assist you here on the Community.
