rjacobsen's avatar
Feb 15, 2024
How do I update Plex on 6.10.10 Firmware RN516?
Yes I searched the forums, today my Admin page said there was an update to 6.10.10 now the Apps upload is broken "App installation is no longer supported with App Upload or Available Apps." WTF!
I'm assuming I'm not the only one who uses the ReadyNAS platform for Plex, has anyone. figured out how to update Plex in the post 6.10.10 world?
Thank you
  • Ya, I'm POed also.  WFT. Netgear just made my NAS worthless!!!  Why the F would they do this.  How am I supposed to update PLEX to anything else I have Installed?  The same goes for EMBY also.
    How do I go back to the last firmware?  I can't afford to buy a new NAS right now.  This one was working just fine until Netgear screwed it's users over.
    Does anyone have a recommendation on a NAS that can handle 4K Plex transcoding, with 6 bays at least.  That is at least as good as a ReadyNAS 516/716?  That isn't out of this world.  ARM is out.
      • JBDragon1's avatar
        JBDragon1
        Virtuoso
        I got the firmware fixed, but it completely screwed up my NAS.  It uninstalled DOCKER and so my Docker apps no longer are running and trying to install Docker fails!!!  I am so mad.  I've lost so much data because of Netgear!!!  Completly uncalled for.  I don't know what to do at this point.
        My Desktop PC is older that my NAS and still works great.  My NAS was working just fine before Netgear screwed it all up.  I am just so pissed!!!
  • plemans's avatar
    Something to keep in mind is the RN516 is EOL. Not saying you can't keep using it but it is a 7 year old device.
    I used to use a NAS for my plex server but noticed a huge performance jump going to a dedicated Plex server.
    A half decent newer Intel processor or an AMD/GPU combination makes a big improvement in transcoding performance.
    I found this plex transcoding cheat sheet worthwhile when adding a GPU.
    https://www.elpamsoft.com/?p=Plex-Hardware-Transcoding
    • StephenB's avatar
      Personally I run Plex on a Win 11 PC, with the media saved on my RN526x.
      Although it is more expensive to separate storage and applications, the benefit is that it is much easier to upgrade when they are kept separate.  For me that outweighs the extra cost.
      • plemans's avatar
        My RN204 couldn't run plex decently. So it's just used for photo/kids data backup now. My Plex is hosted on a AMD 2700x with a 32tb raid array and an older nvidia 1060 for transcoding. Streams 4k without any issues. A bit overkill and the next upgrade will be for an intel for the quicksync capability. I guess its pretty rock solid with plex transcoding
    • bmfb1980's avatar
      bmfb1980
      I laugh at the millenials and younger... you fully believe you must always buy the latest and greatest things... and you wonder why you have no money?  I'm sorry but until the devices just quit on their own, they will have their uses.  I don't need to transcode 4k.  1080 HD/SD is fine for me.  If I want perfect quality, I'll buy a BRD.  There is NO way I'm buying more HDD and desktops and laptops and all the crud they force you to buy when they deliberately make older things obsolete.  I also don't stream ANYTHING and you are foolish to pay for any streaming service.  BUY your music then you OWN it.  Nobody can take it away because of some licensing squabble with an streaming provider lol... sorry I'm just as annoyed at NETGEAR as everyone else.  Guess I won't be buying any of their products also... tired of having to replace them every few years for no reason at all other than they won't make anything backward compatible.  Peace out.
      • fidelisoris's avatar
        fidelisoris
        I'm absolutely shocked they locked out the manual upload for apps. I understand why they want to shut down the online app service, but to hamstring the manual uploads in the process is just ridiculous customer treatment.
        I was already unhappy that NetGear is dropping the NAS products, and was expecting to have to go to a competitor in due time... but to then insult us with this latest firmware is just the cherry on top. NetGear is now on my bad list.
  • Hi,
      Updates are a process to fix problems, not to kill a product line. If there's not a easy/quick fix to this problem, it will be a 10k problem to replace 2 x RN516. Maybe a lawsuit or maybe common sense will prevail! Or dose anyone have another fix to issue. Thanks
      JBDragon1
      Virtuoso
      Ya, the firmware did nothing to fix problems.  All it does is lock you out of installing any more apps and purposely uninstall your software.  WTF is that?  Luckily, I was able to get my NAS back to where it was before this so called update.  But they wasted my time doing it and my software not running for a few days.  I don’t get why Netgear would do such a thing?
      Do NOT install 6.10.10. Hopefully everyone sees this before it’s too late!!!  How many other Netgear NAS’s is this being done on?
      • XtheUnknown's avatar
        XtheUnknown
        Apprentice
        You may also want to double-check that on the Settings tab you have turned off automatic OS  & HotFix updates (and set the update option to Long-Term-Support).
    • StephenB's avatar
      mawcasa wrote:
      Or does anyone have another fix to issue. Thanks
      It should be possible to restore the working apt config from 6.10.9 (and then just use ssh to install packages.
      Netgear appears to have removed https://apps.readynas.com/ (though it might just be a temporary down server issue)
      FWIW, I think it was good to fully remove readycloud from the NAS firmware.  But I'd rather they'd left the apps alone (as they have so far with 4.x and 5.x add-ons).
  • I just found this thead from Googling as I just had the exact problem and solved it.
    As many have already alluded, Netgear are deluded and removed the upload facility in 6.10.10. I thought I was being diligent keeping my firmware up to date & likewise with Plex, but you can't upgrade Plex on 6.10.10.
    I went to https://kb.netgear.com/20684/ReadyNAS-Downloads (RN314) and downloaded 6.10.8 and in the SYSTEMS/SETTINGS Screen when you are logged into you NAS you can upload the new firmware with the INSTALL FIRMWARE Button. Now my NAS is back to 6.10.8 and I was able to successfully upload the downloaded Plex Update file. Handy Tip - Reboot your NAS, Log Out / In on Plex when its all done.
    • StephenB's avatar
      Personally I'd have gone with 6.10.9 myself.
      Though I didn't track down exactly what the security fixes in 6.10.9 are, I generally do want to take them all.
      Two comments:
      1) You still should consider applying the changes to the apt config in this thread:
      Post 37 has download links to the two files you need (courtesy of Sandshark ) but as he notes in his post, he might delete the files from dropbox in the future.  So grab those files, even if for future use.
      Most Plex updates won't need new libraries, but there is no guarantee that will always be the case.  And if they do need a new library, then the update will fail without the config change with 6.10.8.
      2) You can still install from ssh (with those config changes) using 6.10.10 firmware.  And one other user discovered a hack.  Uploading the plex update as if it were a firmware update worked with 6.10.10.
      The benefit of running 6.10.10 is that it also completely removes ReadyCloud from the NAS - which is a good thing, since the service is no longer up.  Someone in the future could attempt to spoof the service, and perhaps compromise the NAS.  No idea what that would take, this is just a hypothetical.  But in general keeping the client running on the NAS does needlessly increase the security attack surface.
      • Moto's avatar
        Moto
        Tutor
        First, a big FU to Netgear for making changes that do nothing but harass their customers, such as getting rid of ReadyCloud so I can't remote into the 516 any more, and now the complete jerk move by preventing us from updating apps like Plex.  So a DOUBLE FU to Netgear, whose tech support and customer support SUCKS.
        Now, on the bright side, Netgear screwed up.  I updated my Plex server on the ReadyNas 516 by uploading it as a manual firmware update.  So screw off, Netgear.  You missed a way to make your customers' experience even more unpleasant, LOL!
ProSupport for Business
