Hotrod1969's avatar
Hotrod1969
Migration from Ultra2 to RN214, Drive swop
Hi,
I have a ReadyNAS Ultra 2 [X-RAID2] running 2 x 2TB drives with RAIDiator 4.2.28 firmware.
This has seen very good service but is now nearing capacity.
I am thinking of upgrading to a RN214. My application is mostly as a Home Media Hub, 3D HD with future proofing to UHD.
Can I simply swop my existing drives into the 214 and add a third 3TB drive? This will give me an immediate additional 3TB of storage with an option for future increase ?
  • StephenB's avatar
    The drive formatting is not compatible, so you will need to copy your data off to external storage if you want to reuse your existing drives.
    • Hotrod1969's avatar
      Hotrod1969
      Many thanks. I think that my strategy will be then to run the new 214 with a single new drive, transfer the data from the Ultra and then swop the two Ultra drives into the 214 and reformat them. Can anyone envisage any snags ?
      • StephenB's avatar
        That should work, assuming no disk errors during the expansion.
        Though I'd get new disks myself (perhaps larger) and use the ultra2 to back up critical files on the RN214.
ProSupport for Business
