ambrosecruz
May 22, 2017Aspirant
RN 214 on AD is read-only
Hello All,
Recently i have updated the firmware of the Readynas to 6.7.1.
When i try to browse the files from the Nas it is giving me only in read only mode and and i am unable to write ...
JennC
May 23, 2017NETGEAR Employee Retired
Hello ambrosecruz,
Can you click Refresh ADS accounts under Accounts > Authentication and see if that helps?
Also try rebooting the NAS.
ambrosecruz
May 25, 2017Aspirant
Hello,
I have tried this serveral times but no luck.
- xiao123Jun 03, 2017NETGEAR Expert
ambrosecruz wrote:
Hello,
Hi ambrosecruz,
If you don't care the previous file access perssion settings, please try reset permission as bellow,
then you would find the Everyone permission chage to be Read-Only at file access page, change it to be Read-Write, try to access your share and write data again via windows client.
- jak0lantashJun 04, 2017Mentor
This is the way to set permissions on a ReadyNAS joined to AD, as recommended by NETGEAR: https://kb.netgear.com/7066/ReadyNAS-OS-6-Setting-Active-Directory-folder-permissions
If you follow that and the GUI still spews errors, then there is a bug somewhere.
