mannythetech
Mar 31, 2016Aspirant
readynas 102 serial number none0002000000 why!!!!!!
i got my readynas from ebay and it has the serial number in the back but on the readycloud web interface it says none0002000000. please help i want to fix this also i try to register it and it says serial number has been registered already.
- mannythetechAspirantohh ok i see got it now
- mannythetechAspirantSo basically I can use everything on the box I just can't get support for it I will have to look for the answers online
- mdgm-ntgrNETGEAR Employee Retired
I can't connect.
Can you boot the NAS to tech support mode (http://kb.netgear.com/app/answers/detail/a_id/22892/~/how-do-i-access-the-boot-menu-on-my-readynas-102,-202,-212-or-312%3F) and let me know the 5-digit number that you then get?- mannythetechAspirant
the nas is on and i went to support and it gave me the number i sent you
The warranty is for the original purchaser only.
Regarding the serial number not showing up in the web admin UI and ReadyCLOUD not working as a result I have sent you a PM.
- mannythetechAspirantOh okay i am having problems installing Plex so I thought it was due to the serial number
- mannythetechAspirantoh ok but can i still get plex and the other features to work or is the Box basically useless
mannythetech wrote:
oh ok but can i still get plex and the other features to work or is the Box basically uselessYou can still use the box and install apps. But you can't get paid support (which frankly has always puzzled me).
The warranty only applies to new units, so netgear won't let you register a used one.
