okba6z
Jul 02, 2015Aspirant
ReadyNas 312 : any disk detected
hi all So here I am playing around with my nas and 2*1To , I received with this except that after finishing my tests etc ... A friend gave me two HDD segeate baracuda st2000dm001 which are ine the ...
Jul 02, 2015Guru - Experienced User
Your instructions are for the wrong product - you have a RN312, not a duo v2. Use the instructions in the hardware manual (http://www.downloads.netgear.com/files/ ... ch2015.pdf)
The software is also quite different from the v2, you will likely want to read through the manual here: http://www.downloads.netgear.com/files/ ... ch2015.pdf
One option is to connect the drives to a PC (USB adapters are fine), and delete the partitions (which is NOT the same as reformatting). Then install the drives into tht NAS with it powered down. IT will then do a factory install.
