okba6z's avatar
okba6z
ReadyNas 312 : any disk detected
hi all
So here I am playing around with my nas and 2*1To , I received with this except that after finishing my tests etc ...
A friend gave me two HDD segeate baracuda st2000dm001 which are ine the official compatible list!
So I have format them and put them in th nas except that here I can no longer access the admin interface nas: s
On RAIDar:
LED is blue
I want to clarify that I have format them on my pc with free partion easus and with seagate discwizard
It's 1 hour I try to do a factory reset by following this tutorial: http://kb.netgear.fr/app/answers/detail ... -duo-v2%3F
1) turn off the nas
2) press the reset button and turned on nas
3) that the LEDs are lit (3LED) released the reset button
4) with the backup button to set the LED disk 1
5) press the reset button to confirm
6) pressed the button to start the backup process?
The nas turns off and on again with the on / off button that blinks constantly
what is his? How can I be sure that I was able manipulation?
Anyway its not work, on RAIDar I ve got boot message then the message any disc detected!
I can ping the nas but not access to the admin interface
After too tempted to do a factory default.
The nas started in boot loop, I sent in warranty and I received new yesterday.
I put in the hard drives I launched a factory default but always same thing, any disk detected
How to know if the factory default is launched?
The disk 1 Led is on and power LED blinks
thanks you in advance for your help
  • I have delete all partition, scan them with wdc lifeguard but always nothing
    Seatools don't see the hard drive!
    The nas to don't see the hard drive
  • StephenB's avatar
    Can you directly connect the drive to the PC (Sata or eSata)?
  • Yes I have do it
    In disk manager, i can see it, i can format it, delete partition etc...
    Seatools don't see it
  • StephenB's avatar
    If seatools won't see these drives when directly connected with SATA, then I would contact Seagate.
ProSupport for Business
