E1b0t
Nov 07, 2016Tutor
ReadyNAS 3312 10TB Drives
Website (http://netgear.com/business/products/storage/readynas/readynas-rackmount.aspx?cid=wmt_netgear_organic) advertise space up to 120TB but no 10TB drives on the compatibility list. When will the list be updated?
Or can you recommend 10TB Western Digital or Seagate drives for RN3312?
- mdgm-ntgrNETGEAR Employee Retired
I have asked engineering for an update on where we are at with qualifying 10TB disks. Only enterprise disks will be suitable for the RR3312. We do have to run some tests to verify whether disks are compatible or not.
- E1b0tTutor
WillI be able to use the WD4002FYYZ (4TB, WD Gold, Enterprise) drive in the unit? This one is also not on the list, but it is an enterprise drive
Disks not on the list may be incompatible. On the other hand they may work fine.
Only enterprise disks are suitable for the RR3312
- komm_itGuide
Hello, Any news about 10TB drives compatibility? (Seagate or HGST)
Those drives have been out for a while now and it would be nice to be able to use them.
Thanx
We are qualifying some disks at the moment, but this does take some time.
Thanks for your patience.
