GTNAS
Dec 13, 2011Aspirant
ReadyNAS NV+
I am looking for backup and storage speed isn't a major concern but I don't want dead slow either. I have the opportunity to buy a used but cared for ReadyNAS NV+ with 1 gig RAM and 4 750 gig drives for about $300 possibly even less, say $250.
Seems to me it would be hard to do better with that money for a NAS solution.
Any reason I should look elsewhere for NAS? Based in eBay sales $300 seems like a good deal with the RAM upgrade and drives.
I plan to use gigabit with jumbo frames for my connection to the ReadyNAS.
Thanks guys I look forward to using a lot of the great information on this site.
- dbott67GuideThe price is definitely right. 8)
The NV+ is a good little unit, albeit a bit long in the tooth when compared to some of the newer model NASes out there. Performance is about 25-30 MB/s when using CIFS/SMB. If using rsync to backup, the CPU will be a limiting factor when performing delta calculations, so backups may take longer than expected when compared to x86-based devices.
I have compiled a performance comparison chart here: http://home.bott.ca/webserver/?p=363
If you're just looking for a device that can capably backup your data, then the NV+ will do the job.
If you're looking for high-end performance (80-100+ MB/s throughput) and have the NAS perform other media-related functions (streaming, ReadyNAS Photos 2, etc.) then you'll need to look at the Ultra or Pro. - GTNASAspirantThanks I think this will be perfect for my needs.
- PapaBear1ApprenticeI have a 4 1/2 year old NV+ that was originally going to be rehomed. When that did not happen, I put it back in service rather than just sit idle. I have two NVX units, one is my primary server and the other is the target for the backups. When I put the NV+ back in service, it was as a second backup for my critical/important files found in two shares. I use rsync for all the backups. The files start backing up from NVX1 to NVX2 at midnight. At noon the next days the critical/important shares start backing up from NVX2 to the NV+. When I have compared the time taken for the rsync, it takes about twice as long to go from NVX2 to NV+ as it does from NVX1 to NVX2. But with rsync, we are talking about 10 typical vs 5 min typical. Keep in mind that rysnc will not work for backups from most PCs to an NAS. Both devices have to be rsync enabled.
My NV+ has served me well and has gone through two drive upgrades since I started with 2x500GB drives. If the unit is sound, it should serve you well.
