jkucukov
May 03, 2018Aspirant
RN2120 Rack Mounting Concern
Today I've finished mounting the Rn2120 with all of its 4 bays loaded into a Hoffman rack. It seems to me that the 6 bolt bracket system holding the ReadyNAS in place are a bit weak making it flex, I can see NAS metal enclosure flexing, is this normal?
Are there reinforcement options for the RN2120 to stiffen the frame or creating 4 points of connection?
- Marc_VNETGEAR Employee Retired
Hi jkucukov
You may want to check RRAIL04-10000S which is the optional sliding rail kit. Please see 1U Rail Install guide
Hope this helps!
Regards
- Frank888NETGEAR Expert
RN2120 is a short depth chassis.
It is designed to fit back to back at the same "U" in the rack mount.
We have done the testing without any slide rail that can pass all the testing requirement.
As Marc_V mentioned, RRAIL04-10000s is the slide rail solution for RN2120 if you need.
Cheers
Frank
