georgeMMXII
Sep 14, 2013Aspirant
RN316+EDA500: Global Hot Spare possible?
Is the following possible? RN316 with 6 disks, 5 used as RAID5 for volume1, 6th as global hot spare; attached EDA500 with 5 disks used as RAID5 for volume2; all disks have same size of 4 TB. A...
vandermerwe
Sep 18, 2013Master
Jedi Knight,
I think you have misread the OP.
mdgm is correct.
The OP wanted a single hot spare in the main chassis to be able to replace a failed disk in either chassis and then for the new disk that is added to replace the failed disk to become a hot spare for both the main unit and the EDA500 again.
mdgm is correct.
