georgeMMXII
Sep 14, 2013Aspirant
RN316+EDA500: Global Hot Spare possible?
Is the following possible? RN316 with 6 disks, 5 used as RAID5 for volume1, 6th as global hot spare; attached EDA500 with 5 disks used as RAID5 for volume2; all disks have same size of 4 TB. A...
georgeMMXII
Sep 21, 2013Aspirant
Thank you for the replies. So a hot spare disk is not limited to single volume but it is limited to chassis it is in.
Another question:
Are volumes also limited to a single chassis or is it possible to create volumes from disks in different chassis'?
For example, is the following possible?
RN316 with 6 disks, attached EDA500 with 5 disks,
all together used as RAID6 for volume1,
Thanks again.
Another question:
Thanks again.
