slayer722's avatar
slayer722
RNRXTRAY1-10000S tray compatiblity
Hello,
I want to know if the tray with this part number RNRXTRAY1-10000S is compatible with my Readynas Duo RND2000 (sparc).
Thanks for your help
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    No. The trays for rackmount devices are not compatible with desktop devices.
    You need the RNDTRAY1
    What happened to your existing drive trays? Was a tray stuck and did it break when you removed it?
  • Thanks for your quick reply,
    My trays have the well know problem with the round button that get stuck, but that's not very important since i have found a great trick for that on the forum.
    I want to buy an additional tray to perform supplementary backups on another hdd.
    Best regards
  • StephenB's avatar
    Just wanted to point out that backing up by inserting a new hdd is generally not recommended here. One issue is that SATA connector on the drive is not built for repeated insertion.
    Another issue is that if you pull / reinsert a drive in the raid array, the full system will resync every time. During the period, the system is not redundant.
ProSupport for Business
