Retired_Member's avatar
Retired_Member
Apr 21, 2019
Three different Linux/Debian releases running on three different type of ReadyNAS
Dear Netgear mods, can one of you shed a light on this riddle? It turns out, that on RN524, RN426 and RN204 three (slightly) different releases of Debian are running.
See details here: https://community.netgear.com/t5/New-ReadyNAS-Users-General/What-version-of-Debian-is-6-9-and-6-10/m-p/1739884#M36292
Differerent processor families might be part of the explanation, but if you know more reasons, please share.
Kind regards
  • StephenB's avatar
    Apr 22, 2019
    Retired_Member wrote:
    So, to my understanding the processor family and the update method make the difference. Any comments?
    Just the processor.  Both my RN102 and RN202 are set to "stable", and I see the same version strings that you do.
    Note you can also see these strings with ssh using
    # cat /proc/version
  • Retired_Member's avatar
    Retired_Member
    To make things as much comparable as possible I downloaded the logs from all my three nas a few minutes ago and I find the following:
    (1) In kernel.log for RN426 on 6.9.5 Hotfix1 Update method: Long-Term support
    Apr 22 01:23:15 nasname kernel: Linux version 4.4.157.x86_64.1 (root@blocks) (gcc version 8.2.0 (Debian 8.2.0-12) ) #1 SMP Wed Dec 19 09:35:08 UTC 2018
    (2) In kernel.log for RN204 on 6.10.0 Hotfix2 Update method: Stable
    Apr 22 01:23:00 nasname kernel: Linux version 4.4.163.alpine.1 (root@blocks) (gcc version 8.3.0 (Debian 8.3.0-2) ) #1 SMP Wed Mar 20 18:04:34 UTC 2019
    (3) In kernel.log for RN104 on 6.10.0 Hotfix2 Update method: Beta
    Apr 22 01:31:13 nasname kernel: Linux version 4.4.163.armada.1 (root@blocks) (gcc version 4.6.4 (Marvell GCC release 20160226-c4af733b 64K MAXPAGESIZE ALIGN) ) #1 SMP Wed Mar 20 18:11:54 UTC 2019
    In the kernel.log of (3) the string "debian" is not even found at all.
    Kind regards
    • StephenB's avatar
      # cat /proc/version
        Retired_Member
        Thanks for the hint, StephenB, I'm downloading the logs on a regular base, anyways.
        Kind regards
ProSupport for Business
