pkraiker's avatar
pkraiker
Trying to use ST3000DM001 3TB drive in USB dock
I have 4 of these drives in my NV+ and want to use them for backups and/or hot swap for the raid array so I picked up 2 more along with a BlacX eSata dock to use for USB backups. This HDD/dock config replaces an older NexStar I've been using with Sata2 drives. Before buying these drives I checked that they were on the supported list. I beleive that's for internal use though, not USB connectivity.
I can format the drives on both my iMac and MacBook using the dock and see the full capacity. When I connect the dock/drive to my NV+ it sees it but says it has a whopping 196.9MB of storage (100% is free though!). I've tried the FAT variations available as well as the journaled Mac FS options. I don't see a way to format EXT anything (running OS/X 10.8.1)
My old backup relied on 1TB drives, with the new config I can't back up on those.
What am I missing? Is there a way to format the drives from SSH? Some parm I'm missing? Not supported (yet)?
And yes I installed the latest firmware before attempting all this. I also looked through the forum and found similar threads but no matches.
PK
ProSupport for Business
