Clarkson's avatar
Clarkson
Upgrade to duo v2
Hi
Because I want to use certain apps I want to upgrade my duo to a v2 from my v1 . If I buy a new one can I just put my drives
In from the old one.
Will it read data ok etc.
Cheers
John
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    No. The RAID format is different.
    Anyway the Duo v2 is discontinued as well. You may as well buy a RN102 and transfer your data across your network to the new NAS then use your Duo v1 as a backup NAS.
  • Hi
    Thanks for reply
    If I copy data to another drive say laptop and reformat disks will that work?
    Cheers
    John
    mdgm-ntgr
    Yes. If you do a factory default the v2 should format the disks.
ProSupport for Business
