atz6975's avatar
atz6975
Guide
Sep 20, 2008
WD10EACS: Huge Load cycle count [ NOT SOLVED] in 4.2.9
Hi,
could ze jedis give their opinion on the following situation:
While checking my smart values after a forth drive expansion (4x1TB) I found that my three other drives that are 7 months old have +200 000 Load Cycle Count
Raw Read Error Rate	0
Spin Up Time 7725
Start Stop Count 834
Reallocated Sector Count 0
Seek Error Rate 0
Power On Hours 4995
Spin Retry Count 0
Calibration Retry Count 0
Power Cycle Count 9
Power-Off Retract Count 7
Load Cycle Count 218854
Temperature Celsius 34
Reallocated Event Count 0
Current Pending Sector 0
Offline Uncorrectable 0
UDMA CRC Error Count 0
Multi Zone Error Rate 0
ATA Error Count 0
While checking some forums, I find that this situation is somehow disturbing, at least confusing...
It is stated that :
1) This kind (wd gp) of drives is designed for 300k-500k Load cycle count
2) Many Linux environments generate very high Load cycle count and are worried about
such counts growth (76+ / hour)
3) WD has issued a WDIDLE3 DOS only, SATA only, tool that can enable/change timer/disable the current default 8s timer for Intellipark.
4) This could also somehow be achieved with hdparm
5) Some Unix HD flushing mecanism must also be considered
Please, please, please, as you now that many of us are happy (even with spin down off) Users of such disk, could you create an add-on or fix or statement on how to avoid this situation.
I'm more than ready to disable "intellipark" and run WDIDLE3 on many, many, many drives.
....or to run away from these drives (although $$$$ losses will hurt)...
To all wd10eacs and other wd gp drive users please post your Load Cycle Counts (LCC) here to help asses the situation.
Thank you.
ProSupport for Business
