Quietis
Mar 15, 2012Aspirant
WD2002FAEX or WD2002FYPS for NV+
I found RE4-GP WD2002FYPS in NV+(RND4000) HCL of Chinese web page of ReadyNAS on March 13th,and then ordered a set of NV+ from an online shop. However,when I received a RND4000(v3,produced ...
PapaBear1
Mar 16, 2012Apprentice
The NV+ v2 is deemed an entry level box and has fewer features than any of the other ReadyNAS boxes including the discontinued NV+ v1 (which originally was designed for both consumer use as well as professional use). Given that, it is in my opinion unlikely you will ever see enterprise class drives on that HCL. After all, those who want entry level boxes are unlikely to spend twice the amount per drive to get the enterprise class drives.
