dat4wd
May 10, 2009Aspirant
WD2002FYPS - 2TB
Just upgraded from original Seagate 1Tb to brand new Western Digital 2Tb WD2002FYPS in a ReadyNAS 1100.
All right!
/Dat4WD
All right!
/Dat4WD
- midspaceAspirant
dat4wd wrote: Just upgraded from original Seagate 1Tb to brand new Western Digital 2Tb WD2002FYPS.
All right!
/Dat4WD
Sweet! You're the first person I've seen on here say they have one of these drives in a ReadyNAS. Everyone else seems to have the WD20EADS.
Any issues, problems getting it in and working? - dat4wdAspirant
midspace wrote: dat4wd wrote: Just upgraded from original Seagate 1Tb to brand new Western Digital 2Tb WD2002FYPS.
All right!
/Dat4WD
No problem. No issues. All works fine! - davec1AspirantI'm thinking about upgrading to from Seagte750's to WD2002FYPS. Looks like its been about 2 months since this was posted - any problems?
Thanks - dat4wdAspirant
davec wrote: I'm thinking about upgrading to from Seagte750's to WD2002FYPS. Looks like its been about 2 months since this was posted - any problems?
Thanks
No problem as before... - MuxjeAspirantI popped a WD2002FYPS into my NV+ the other day. Initialisation and resynching went fine, but I did get the insanely fast increase in "load cycle count" that others have reported. Are you guys seeing the same thing (in the SMART information for the drive, obtained via FrontView)? My old plain (non-Green) WD's have racked up something like 2500 Load Cycles in over a year of service, the WD2002FYPS got to the same amount in a matter of days, and it will hit the maximum rated cycles before the year is out at this rate.
WD have acknowledged a problem with the "Green" feature of their newer drives, especially in combination with Linux or various NAS boxes. For the 750G to 1.5TB drives they have released a utility that disables the Green feature, but the tool does not work on the 2TB drives (yet). Until they address this issue, I'm not using these 2TB drives in my ReadyNAS. - dat4wdAspirantSorry, but SMART-info only in russian. Only 8 hardware errors on disk 1.
--- disk 1 ---
Информация SMART для Диск 1
Модель: WDC WD2002FYPS-01U1B0
Серийный: WD-WCAVY0091644
Встроенное ПО: 04.05G04
Атрибут SMART
Частота аппаратных ошибок чтения 8
Время раскрутки пакета дисков 0
Полное число запусков/остановок шпинделя диска 12
Число операций переназначения секторов 0
Частота ошибок при позиционировании блока головок 0
Число часов, проведённых во включённом состоянии 1852
Число повторных попыток раскрутки дисков до рабочей скорости 0
Количество повторов запросов рекалибровки 0
Количество полных циклов включения-выключения диска 2
Число повторов автоматической парковки блока магнитных головок в результате выключения питания 1
Число циклов перемещения блока магнитных головок в рабочее положение. 200002
Температура, С 36
Число операций переназначения 0
Число нестабильных секторов на замену 0
Число некорректируемых секторов 0
Число ошибок, возникающих при передаче данных по внешнему интерфейсу 0
Общее количество ошибок, происходящих при записи сектора 0
Счетчик ошибок ATA 0
Расширенный атрибут
События Hot-add 0
События Hot-remove 0
События Lp stat 530
Выброс на шине питания 0
Сбросы/перезагрузки жесткого диска 0
Попытки 0
Восстановленные секторы 0
--- disk 2 ---
Информация SMART для Диск 2
Серийный: WD-WCAVY0108773
Атрибут SMART
Частота аппаратных ошибок чтения 0
Число часов, проведённых во включённом состоянии 1840
Число повторов автоматической парковки блока магнитных головок в результате выключения питания 2
Число циклов перемещения блока магнитных головок в рабочее положение. 99513
Температура, С 36
Расширенный атрибут
События Hot-add 0
События Lp stat 6409
Попытки 0
--- disk 3 ---
Информация SMART для Диск 3
Серийный: WD-WCAVY0104692
Атрибут SMART
Число часов, проведённых во включённом состоянии 1821
Число циклов перемещения блока магнитных головок в рабочее положение. 64162
Температура, С 36
Расширенный атрибут
События Hot-add 0
События Lp stat 1660
Попытки 0
--- disk 4 ---
Информация SMART для Диск 4
Серийный: WD-WCAVY0105105
Атрибут SMART
Число часов, проведённых во включённом состоянии 1806
Число циклов перемещения блока магнитных головок в рабочее положение. 200003
Температура, С 36
Расширенный атрибут
События Hot-add 0
События Lp stat 5
Попытки 0
Восстановленные секторы 0 - MuxjeAspirant
If my poor grasp of Russian is correct, this is the load cycle count. That is a rather high and unusual number, for only 1850 hours of uptime. Others have stated that these drives are rated for up to 300.000 load cycles, but I don't really know if that is accurate, and what happens if the drive exceeds this number.
In comparison, my old WDC drive shows over 8500 hours of uptime, and has had only 1900 load cycles. - muggsyAspirant
Muxje wrote: Число циклов перемещения блока магнитных головок в рабочее положение. 200002
it's why I am avoiding having my pro on for too long, because I am so conscious of the load cycle count of the 2 drives I have in there. Fingers crossed something is added for new betas or WD step up to the plate and issue a new firmware like they did for the 1TB drives - dat4wdAspirant
Yes! You right. I havn't any idea how to fix it. What do you think - wich side is responsibility for this issue - Netgear or WD? - MuxjeAspirantResponsible? Hard to say... It's WDC's drive falling asleep too fast, and the ReadyNAS waking it up too soon. :) Apparently this issue occurs on many Linux based systems including various NAS systems.
WDC make a tool called WDIdle3.exe with which you can turn off the Green sleep feature (Google for the tool, it's not on the WDC site). You need to connect the drive to a pc (disconnect all others), then boot into DOS and run the tool. I've done that on one drive yesterday and according to the logs, the Load cycle count has been increasing normally so far. For further explanation see this thread: viewtopic.php?f=24&t=25733
