ilansch
Dec 06, 2016Aspirant
Where are the system logs
Hi, I am running a certain demon on a ReadyNAS OS 6.5.1 machine.
The demon print logs, usually the logs are located at: /var/log/messages or /var/log/syslog.
Where is does the logs output in readynas? the /var/log/ is missing some log files and dmesg does not contain all logs.
We use systemd. You can use the journalctl command
1 Reply
- mdgm-ntgrNETGEAR Employee Retired
