daniele76
Mar 20, 2016Aspirant
Impossible to install Apps (update problem with 6.4.2OS) #26554085
Hello guys! I hope this is the right section for this topic...
I'm using my ReadyNAS with 6.4.2 OS on a NETGEAR ReadyNAS 102. Since a while, it seems to be impossible to install App in the web-based admin utility both choosing the apps proposed in the default list and uploading *.deb files (I'm trying to install monsta_1.4.2_all.deb).
A message about an update problems of the apps list appear for less than 1 sec (impossible to read it), then the admin utility close and re-start.
I tryed to activate SSH and I used a atp-get update command. The got this error, before to exit:
Err https://deb.nodesource.com wheezy/main armel Packages HttpError404 Fetched 11.6 MB in 44s (264 kB/s) W: GPG error: https://deb.nodesource.com wheezy InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 1655A0AB68576280 W: Failed to fetch https://deb.nodesource.com/node_0.10/dists/wheezy/main/binary-armel/Packages HttpError404 E: Some index files failed to download. They have been ignored, or old ones used instead.
I asked to Netgear's support, but I got only a request to buy a support package even to read my message...
I'm sure I could find more friendly advise here!
Thank you very much!
Daniele
- mdgm-ntgrNETGEAR Employee Retired
Which apps do you currently have installed?
What does your /etc/apt/sources.list look like?
- daniele76Aspirant
Really sorry for the delay, I couldn't use the machine during last week...
I partially solved the problem, fixing a missing library with apt-get install -f: now I'm able to install new apps.
However no changes in the sudo apt-get update problem...
I have installed: Gateone (but I'm thinking to remove it, I can use terminal...), Transmisison, PHPMyAdmin and (now) Monsta FTP Client.
My sources.list:
Spoilerdeb http://apt.readynas.com/packages/readynasos 6.4.2 updates apps main
deb http://mirrors.kernel.org/debian wheezy main
deb http://security.debian.org/ wheezy/updates main
Daniele
Can you send me your logs (see the Sending Logs link in my sig)?
- daniele76Aspirant
my sources.list:
deb http://apt.readynas.com/packages/readynasos 6.4.2 updates apps main deb http://mirrors.kernel.org/debian wheezy main deb http://security.debian.org/ wheezy/updates main
Daniele
