gksolutions
Sep 13, 2016Aspirant
NAS RN 516 disabled and greyed-out within Replicate
My latest NAS (RN 516), labeled NAS-RDN-NL seems to be disabled and greyed-out within Replicate...?
Device Name: NAS-RDN-NL
Device Model: ReadyNAS 516
Device Serial: 3C82350N01C41
Firmware: 6.5.1
Updated firmware on the PRO and rebooted the NVX. Both the PRO and the 516 are working with Replicate and am currently running a backup job now. I will try to get the NVX running again in Replicate sometime in Q1 2017. If I run into any issue with it, I'll create a new post specifically for it.
Truly appreciate all your time, patience and guidance, so big thanks again!!
- mdgm-ntgrNETGEAR Employee Retired
You've got a lot of DNS Server addresses configured. Are they correct?
Can you pdate to 6.5.2?: http://kb.netgear.com/app/answers/detail/a_id/31116/~/readynas-os-version-6.5.2Your logs are flooded with SSH connection attempts. Best not to port forward SSH if you don't need to.
- gksolutionsAspirant
The only DNS IPs should be 86.116.46.20 and 86.116.46.21. The others can/will be removed.
Have also removed forwarding of port 22 on router. Hopefully the attempts were only from yesterday. I was in via SSH yesterday trying to reboot/restart remotely since I couldn't get into Frontview locally (via RDP or Teamviewer to locally attached computer) and it wasn't restarting via RAIDar.
Will update to 6.5.2 once I can get back into Frontview.
...should I also update my ReadyNASRNDP6000v2 to 6.5.2 which is on the same local LAN network?
If that's running OS6 too then yes you should update it.
...sorry DNS IP should be 84.116.46.20 and 84.116.46.21
