yoh-dah
Mar 06, 2008Guide
ReadyNAS Photos troubleshooting tips
If you're having problems getting ReadyNAS Photos to work, see if any of the following tips will help.
1. If you are in User or Domain security mode, and you don't have "public" or "guest" access enabled for the [media] share, you will need to specify a login and password to connect from the ReadyNAS Photos desktop software. The login and password should be what you would normally use to connect to the [media] share.
2. If you are in Share security mode, and you have a password set for the [media] share, when connecting from the ReadyNAS Photos desktop software, leave the login field blank, and enter the share password.
3. If you are in User or Domain security mode, and you are an account on the ReadyNAS with the same user name but a different password as what you are using on your PC, you will need to change the password to be the same.
4. Make sure [media] share has read/write privileges over CIFS.
5. If you have installed a pre-release version of RAIDiator that had ReadyNAS Photos support (shame on you since we never really released it ;-) ), and you're having problems with the READYNASPHOTOS database, you will need to remove the ReadyNAS Photos add-on, and re-install the add-on from here.
- jambalayaAspirant
I began using this NAS about a month ago. Everything is working nicely, but readynas photos is just a string of constant problems. Seems like something about it is half-baked somewhere - either on the unit, somewhere on netgear's end, in the software, or a combination thereof. It's just been one frustration after another with this. I'm tired of having this work only to one day wake up and have it not work and then hear from everyone that I shared albums with that they can't access my photos.
Amen to that I like the software but if Netgear doesn't support it they shouldn't even waste the time by including it with their hardware package.
It's obvious there are problems with the external server that the application is connecting with. Last week it email not getting sent this week it's something else.
Can we expect that this is going to happen on a regular basis? If so I need to look for other options. - knowramAspirantI just installed readynas photos and am trying to set it up but haven't gotten the account confirmation email and i tried setting up my account 20 min ago. Looks like email is down again.
- minervaAspirantCurrently I don't see any issues with emails. Hope you have received the confirmation email. In case you haven't , could you let me know the email address that you have tried to signup with?
- strange1AspirantI have ReadyNAS Ultra6 with RAIDiator 4.2.15, and have a problem with using ReadyNASPhotos (got 'Invalid credentials' when trying to login).
What i did:
- install ReadyNas_Photos_2.2-x86.bin addon
- install ReadyNASPhotosInstallerWithJava.exe (v1.1) on my WinXP.
- start application, register on www.readynasphotos.com as user strange and sucessfully Sign in (for that step i have enter my http proxy server address in application options). Application (opens in Firefox 3.6.10) discover my NAS on address 172.16.10.106, but I cant use it!
- see page http://localhost/readynas/template/index.jsp?pageId=settings
Host Name: ULTRA6
IP Address: 172.16.10.106
+ Requires authentication for media share
Username:
Password:
- fill Username and Password fileds with my account, that I added to NAS, ('media' share sucesfully opens with that login/password from my WinXP 172.16.10.2) But i've got 'Invalid credentials' in case of strange/guest or even empty username.
- i try to change 'media' options to read/write to everybody or only to strange - nothing helps
- then I try using ReadyNASPhotosInstaller-2.0.RC1WithBundledJava.exe, and get same result.
- I have read forum about that promlems, find many same issue, but no answer, thet helps me or any detailed problem description.
What steps should i try to make ReadyNAS Photos works ? - sanecaAspirantI have the same problem. I am using the Readynas NV+ in domain mode. I am logged into my pc using my active directory user name and password. I try to use the same username and password to connect to the readynas and it won't connect. "Unable to connect to ReadyNAS Photos share on 192.168.1.102. Is the ReadyNAS Photos service enabled ?" If I had a nickel for every time I've seen this lately! Anyone know how to connect to this thing. This would be a great service if it worked. I would love to share more photos than the 25Gb windows live space can hold and this seems to be a great way to do it. Thanks.
- pstoopAspirantSame problem here. But I got it solved after some trail and error.
Working in the IT business for 20+ years, now, got me convinced that software design glitches loom everywhere.
Obviously there seems to be an authentication problem, here. So I started altering the NAS password for my ReadyNAS Photo user.
What I found out is that the authentication engine either ignores or misinterprets non-letter and non-digit characters in a password.
Actually, I had the same issue before when trying to set the NAS's admin's password containing special characters.
So only A..Z, a..z, and 0..9 are allowed in the NAS's password scheme.
Hope this helps,
Patrick - BruceReedAspirantHmm, this is distrubing. I've used ReadyNAS in businesses for a few years, but just started using one personally and add-ons like Photos are appealing and one of the reasons I installed one in my house. The album manager/uploader crashes on Mac OS constantly as documented in other posts. I can't get a single album processed.
Agree with others here that because this is a Netgear supplied add-on it should either work or be moved into community status. - malarkyAspirantHi,
I'm having a problem that I can't find described on the forum.
I've got a Duo. I've installed the photos add-on. I've got an account at readynasphotos.com. I've installed the java software on my Ubuntu netbook and run it from /home/[user]/dekoh.sh.
It opens:
http://localhost:1025/readynas/template/index.jsp?pageId=settings
in Firefox 3.6.17. I login.
The 'discover' circle goes around a few times and it says 'No ReadyNAS device found'.
I can 'Add ReadyNAS host' at 10.1.1.200, with no credentials, or with credentials and it says 'invalid credentials'. I'm guessing that the invalid credentials are because it can't find the ReadyNAS, not because it has an issue with the credentials.
Any help on where I should start with this would be greatly appreciated. - minervaAspirantCan you download and run RAIDar and see if it can discover your ReadyNAS ?
http://www.readynas.com/?cat=41
Are you able to connect to your ReadyNAS using the Frontview ?
-Minerva - malarkyAspirantThanks for getting back Minerva.
I don't normally use RAIDar because I have a static IP for the ReadyNAS and I log into it regularly through the browser. But I installed RAIDar, it discovers the NAS straight away, locate button works, and set up works.
-Malarky.
