stevenestrada
Mar 18, 2018Aspirant
Another root volume full
Getting this after the the 6.9.3 update
System volume root's usage is 81%. .
System volume root's usage is 82%.
Someone suggested deleting apps. So I ldid. Deleted loganalyzer that never worked, and istat. Have only smbplus. Someone ese said get rid if mysql. Doesn't the system need that?
# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.3G 448M 89% /
tmpfs 992M 0 992M 0% /dev/shm
tmpfs 992M 4.3M 988M 1% /run
tmpfs 496M 2.0M 494M 1% /run/lock
tmpfs 992M 0 992M 0% /sys/fs/cgroup
/dev/md126 3.7T 2.1T 1.6T 58% /vol_lun
/dev/md127 3.7T 2.5T 1.2T 68% /vol_data
/dev/md127 3.7T 2.5T 1.2T 68% /apps
/dev/md127 3.7T 2.5T 1.2T 68% /home
/dev/md127 3.7T 2.5T 1.2T 68% /var/ftp/Music
/dev/md127 3.7T 2.5T 1.2T 68% /var/ftp/shared
/dev/md127 3.7T 2.5T 1.2T 68% /var/ftp/Videos
/dev/md127 3.7T 2.5T 1.2T 68% /var/ftp/Zipped
tmpfs 4.0K 0 4.0K 0% /var/ftp/Music/snapshot
tmpfs 4.0K 0 4.0K 0% /home/steve/snapshot
# date
Sun Mar 18 08:14:43 EDT 2018
# df -h
root@SAN1:/var/lib/mysql# df -h
/dev/md0 4.0G 3.3G 406M 90% /
# du -xhd1 /
6.7M /bin
0 /boot
12M /etc
33M /lib
4.0K /lib64
0 /media
0 /mnt
4.6M /opt
32K /root
11M /sbin
0 /selinux
0 /srv
0 /tmp
460M /usr
1.4G /var
61M /data
31M /frontview
2.0G /
du -xhd1 /var
0 /var/opt
83M /var/backups
0 /var/local
54M /var/log
4.0K /var/spool
0 /var/mail
44M /var/cache
1.1G /var/lib
0 /var/tmp
4.0K /var/www
8.0K /var/netatalk
0 /var/agentx
50M /var/cores
0 /var/ftp
13M /var/readynasd
0 /var/target
0 /var/crash
1.4G /var
The system doesn't use it, and it is not normally installed. I believe in your case it was needed for loganalyzer.
- stevenestradaAspirant
Every update is another problem with this thing
That innodb trick reads like it'll take a big (650M for me) file and turn it into a bunch of little ones.
Im afraid to do that or shuffle stuff around with symlinks, etc figuring it explode into a bigger problem with the next update
The readynas OS don't need mysql?
I'll shut it off and see what happens
Is this how to get rid of it entirely:
# apt-get remove --purge 'mysql-.*'- StephenBGuru - Experienced User
Correct.
- mdgm-ntgrNETGEAR Employee Retired
If you don’t need MySQL you can remove it using apt-get.
- Retired_Member
I think /var/lib/mysql/ibdata1 file could consume 1GB OS partition space of your device,to shrink this file you can navigate website
https://www.thegeekstuff.com/2016/02/mysql-innodb-file-per-table/
Another option is to stop MySQL, move the MySQL database to the data volume and create a symlink.
