masa2's avatar
masa2
Tutor
May 24, 2012
Connecting ReadyNAS Duo from Internet
Hello.
I'm setting up my ReadyNAS Duo drive to my LAN and would like to be able to connect it from everywhere I want.
Is it possible to do it any other way than installing ReadyNAS Remote application to every computer where I like to connect? For example: Will this work with port forwarding?
I would like to be able to map a network drive to NAS and also connect it via web browser.
Thanks!
  • StephenB wrote:
    Ok, you do have a V1. That gives you more options for remote access.
    Personally I don't use WebDAV. Instead I have enabled FTP for my shares, and use FileZilla as my PC client. The Duo does support a secure FTP connection (FTP over Explicit TLS)
    Secure FTP works great for me on my Duo v1 :-)
ProSupport for Business
