bushtor1
Jun 05, 2013Aspirant
Connection refused - rsync from BackupAssist
Hi, I have purchased a ReadyNAS Pro 2 (RNDP2000) fw RAIDiator 4.2.23 It has been set up with a rsync share, rsync access is enabled and I entered an rsync user with password. BackupAssist has thr...
bushtor1
Hi and thanks for the reply.
I read the article you mention before I posted, but as I understand it, the two described scenarios are both 'controlled' by the ReadyNAS box.
In my case the backup process is controlled by the BackupAssist application (from a windows server), and the ReadyNAS box is just supposed to accept the connection, provide the rsync service and receive the files.
So I need ReadyNAS to act as a server which only accepts rsync connections from other (BackupAssist) hosts. In BackupAssist I can enter a username / password to access the rsync server. Should it be possible to connect using this user credentials when I connect, or do I need a key file? If the latter is the case, I assume that it should be created at the BackupAssist server?
Thanks for comments on this
regards Tor
regards Tor
