bishoptf
Feb 12, 2012Aspirant
Crashplan for Dummies, aka Step by Step :)
I have just went through this and have seen several folks post that they wish there was an all inclusive guide, I just bought a Pro 2 and so far I am pleased with what I see under the hood (looks like debian to me, kernel 2.6.37) I'm a *nix guy so I thought I would try to make an all inclusive step-by-step to help anyone that might want to try and install crashplan. So here goes, the normal warning goes here - There are no warranties implied or otherwise, DO THIS AT YOUR OWN RISK! If you find any thing that needs to be updated or doesn't make sense please post and let me know...
I am not the only one to post how to do this see here - http://www.readynas.com/forum/viewtopic.php?f=61&t=18139&start=15#p297737
and here http://support.crashplan.com/doku.php/how_to/configure_a_headless_client
Steps for x86 ReadyNas Only:
Old way,still works but uses java 6, which is out of date:
Updated JAVA install, credit goes to InterClaw :)
The full instructions can be found here - http://minimserver.com/ejre-installer.html I will try to list just the steps for x86 ReadyNas:
1. Go to Oracle and down load the latest embeeded java version l@@k for this version - x86 Linux Small Footprint – Headless - http://www.oracle.com/technetwork/java/embedded/downloads/javase/index.html
*Note you will have to accept Oracles Terms and Conditions and create an account to download the file
2. Download file and copy the java file to /c/backup/ on your ReadyNas
3. Download the EJRE Readynas Addon see the link above for the full instructions, the addon can be found here - http://minimserver.com/downloads/EJREInstaller-0.10-readynas-x86.bin
4. Install EJRE Addon and this will install the java version that you placed in /c/backup/
5. Verify that java is working, time to jump to the command line to finish the installation. Install the Enable Root SSH addon - http://www.readynas.com/download/addons/x86/4.2/EnableRootSSH_1.0-x86.bin Complete installation by rebooting your readynas.
6. You will need to get a ssh client for your desktop/laptop, here is one for winblows (putty) - http://the.earth.li/~sgtatham/putty/latest/x86/putty.exe, nothing to install, just download and place on your desktop or somewhere you can find it.
7. Open putty and SSH into your readynas, enter the IP address and when it prompts for username enter "root" and then your normal raidar/frontpage "password". Once logged in verify java operation by entering the following :
8. Now we can install Crashplan.
- Download the latest linux crashplan version
enter "wget the latest version that is listed on crashplan for linux, see below"
Here is the main download page, just make sure you get the latest version -
http://www.crashplan.com/consumer/download.html?os=Linux, this will download andplace this in your
root directory.
9. Once the diownload has completed lets extract the files which are tarred and zipped.
enter "tar -xvf CrashPlan_3.0.3_Linux.tgz" or whichever version you downloaded, this will extract all of the files
and place them in a folder called "CrashPlan-install".
enter "cd "CrashPlan-install" and then run the installer, enter "./install.sh", this will start the installer
ask for you to accept the terms and conditions and ask questions where to install etc..You can accept the defaults
for most, however when it prompts you for the default crashplan backup directory, you can go with the default or
provide a directory that you have already established for that purpose, e.g., "/crash-backup" whatever your share
that you created without any slashes, this actual is a pointer to "crash-backup -> /c/crashplan-backup"
Here are the questions, most you accept the defaults, in this case I chose to specify a different Directory -
Do you accept and agree to be bound by the EULA? (yes/no) yes
What directory do you wish to install CrashPlan to? [/usr/local/crashplan]
What directory do you wish to link the CrashPlan executable to? [/usr/local/bin]
What directory do you wish to store backups in? [/usr/local/var/crashplan] /crash-backup
What directory contains your SYSV init scripts? [/etc/init.d]
What directory contains your runlevel init links? [/etc/rc2.d]
Your selections:
CrashPlan will install to: /usr/local/crashplan
And put links to binaries in: /usr/local/bin
And store datas in: /crash-backup
Your init.d dir is: /etc/init.d
Your current runlevel directory is: /etc/rc2.d
Is this correct? (y/n) [y] y
10. Configure crashplan on the readynas, in order to do this you need to download and install crashplan on a local PC,
using linux, winblows or Mac - http://www.crashplan.com/consumer/download.html once that has been
done we need to tunnel from the PC to the readynas, the already have this detailed on the crashplan site
called a headless install - http://support.crashplan.com/doku.php/how_to/configure_a_headless_client
*Note while configuring the Crashplan client -the client will show your shares twice - as links (with an arrow as part of the icon)
and under the "C" folder. It won't back up the links, you need to select the folders under the "C" folder. If you try the other way, the
backup "succeeds", but doesn't back anything up. Thanks to StephenB for this update!
Once the configuration is complete you should be good to go.. :)
I'm sure I have left something out or not fully explained something, if so let me knoiw and I will update the posting..
Good Luck :)
1. See Step one below
2. See Step two below
3. See Step three below
4. Once logged onto your readynas as "root" your ready to get the the software setup. Keep in mind that when you are running as root, you have elevated priviliges and you can do anything you want, including messing things up, so go slow and take your time :)
- First thing we need to do is edit the sources.list, we are going to use vi which is not a friendly editor
but is installed on any base *nix system and in this case will get the job done. Lets edit the file, at
the prompt - vi /etc/apt/sources.list, arrow down to the last line and then arrow over to the
last letter and hit the "a" button for append and then hit "enter" to get a new line and then paste
"deb http://archive.debian.org/debian-backports etch-backports main non-free" .
- To get out of vi and save the file "shift:" will get you the colon prompt at the bottom, then to save
and exit enter "x", if you made a mistake and you do not want to save your work at the colon enter "q!"
and that will quit without saving any changes. Once you exit and save your sources list should look
like this, "more /etc/apt/sources.list" -
deb http://www.readynas.com/packages 4.2.19/
deb http://archive.debian.org/debian etch main
5. Now we need to update our package list and install Java.
- enter "apt-get update"
- Now we need to modify configuration dialog selection so we can accept the java Terms and conditions.
- enter "dpkg-reconfigure debconf"
This will ask you to select a dialong frontend, select option 1 - Dialog, then it will ask you for
the level, select option 3 - Medium.
- Now lets install java, enter "apt-get install sun-java6-jre", it will download the package and start to
install it where it will ask for you to accept the terms and conditions, select yes and complete the
installation.
- Modify the deb configuration and change it back, enter "dpkg-reconfigure debconf"
This will ask you to select a dialong frontend, select option 6 - Noninteractive, then it will
ask you for the level, select option 3 - Medium (not sure if this was the default).
java -version
root directory.
Your selections:
Good Luck :)
- tony359ApprenticeHi Sdouek
It works like a charm! Much easier than creating the tunnel - even though that is handy when you want to check the status remotely and only port 22 is being forwarded!
Thanks, I'm amending my guide now.
Edit: do I still need to change the service port to 4200? Will that be useful in case someone needed to open an SSH tunnel from the outside world? Is it still needed for the average user? I could move it to the 'tweaks' section.
Come on, I want feedbacks! - tony359Apprenticeit sounds cool, I'll test it when I'm back home and I'll add it to the list if it works, thanks
- sdouekGuideI noticed that if you don't want to keep opening putty every time you want to connect to your NAS you can do the following.
I make no guarantee that this will work but it has worked for me on my NAS PRO 6 and if you don't know what you are doing don't do it.
Step 1:
I recommend you make a copy ui.properties of the file before editing them. It should be in C:\Program Files\CrashPlan\conf\
On the PC you are using the crashplan GUI Edit the ui.properties file: Change serviceHost=NAS.IP.ADDRESS and rem out everything else
Step 2:
Stop crashplan by SSH into your NAS and type incd /usr/local/crashplan/bin
then type in./CrashPlanEngine stop
Step 3:
I recommend that you make a copy of the file my.service.xml. SSH into your nas and change to the directorycd /usr/local/crashplan/conf
and typecp my.service.xml my.service.xml.bak
On the Nas unit you can either use Win CP (it has a built in editor and a windows gui) or Putty to ssh into your machine and use vi.
Edit my.service.xml located in /usr/local/crashplan/conf. Change <serviceHost>127.0.0.1</serviceHost> to <serviceHost>Your.NAS.IP.ADDRESS</serviceHost>.
Step 4:
Start crashplan by either rebooting or by SSH into your NAS and type incd /usr/local/crashplan/bin
then type in./CrashPlanEngine start
There now if everything was done right when you click on Crashplan on your PC you will no longer need to open putty and establish a tunnel. - tony359ApprenticeHi,
As discussed elsewhere, I am now trying to put together an updated step by step guide for installing CP on an OS4 Intel x86 NAS. I hope this could be useful for someone. Please understand that I am not a Linux guru so I may say some nonsense, do not hesitate to point out what is wrong.
Below the tentative. I hope I can come back and amend it while we work on it. Otherwise I'll need the admin's help! :)
I have a question regarding the global Java location for the system. I do not think that using the link I mentioned is correct. It works, but not sure it's the right thing to do.
Also, is there an easier way to install Java by using apt-get?
Thanks everybody.
CrashPlan Headless install - For dummies . Updated for CrashPlan 4.3.0 - 07/07/2015
What is a 'headless' install?
CrashPlan can be installed directly on a NAS. It will run as a service in background. However, we cannot connect a monitor to operate CrashPlan's GUI directly on the NAS. This makes the NAS "Headless". To operate and configure CrashPlan on our NAS we will use CrashPlan for Windows/Mac/Linux and redirect the GUI so it controls the NAS instead.
INTEL x86 based NAS
Step 1: INSTALL SSH
SSH allows the user to open a Linux terminal screen on a Windows/MAC/Linux computer so the NAS can be operated at Linux level.
Install the following add-on http://www.readynas.com/download/addons ... .0-x86.bin by following the below steps:
- open FrontView
- Navigate to Add-Ons
- Click on ADD NEW
- Browse to the file and click UPLOAD AND VERIFY IMAGE
- The NAS will install the add on for you
To SSH into the NAS by putty (open source app)
- Download putty at http://the.earth.li/~sgtatham/putty/lat ... /putty.exe
- putty does not require installation. Double click on the file, type the IP address of your NAS on "HOST NAME (or IP address)". Make sure that CONNECTION TYPE is set to SSH and click OPEN
- Putty may warn you about some security issues, click on OK to continue
- login using root as user name and the password used for the admin user on frontview.
- nothing to do at this stage, just leave the window open.
Step 2: INSTALL JAVA (this is apparently not needed anymore from version 4.2.0 onwards)
- Browse to the Oracle website and download the latest x86 Linux Small Footprint – Headless The download page is: http://www.oracle.com/technetwork/java/ ... index.html
- Save the file on your NAS on the BACKUP share
- Download and install the following add-on: http://minimserver.com/downloads/EJREIn ... as-x86.bin
- The above add-on will install the Java package we have just saved on the BACKUP share. When Java has been installed, switch back to the SSH window (open a new one if you had to reboot the system) and type the following command:java -version
If Java was correctly installed the system will reply with something likejava version "1.8.0_33"
Java(TM) SE Embedded Runtime Environment (build 1.8.0_33-b05, headless)
Java HotSpot(TM) Embedded Server VM (build 25.33-b05, mixed mode)
Step 3: INSTALL CrashPlan
Navigate to CrashPlan's website and download the Linux version. Save it on the BACKUP share of your NAS. using wget is easy but getting the URL is not. I believe this is an easier alternative.
Back on the SSH terminal window, type the following commands (assuming that CrashPlan_4.3.0_Linux.tgz is the file you've just downloaded)cd /backup
ls
(this will list the files currently in your share. Identify the latest CrashPlan file you've just saved)cp CrashPlan_4.3.0_Linux.tgz /root]
(replace CrashPlan_4.3.0_Linux.tgz with whatever is the file you've just downloaded)
- Now the file is being copied to the root folder. Navigate to the root folder and extract the archivecd /root
tar -xvf CrashPlan_4.3.0_Linux.tgz
(again, replace CrashPlan_4.3.0_Linux.tgz with whatever you've just copied)
Type ls and you will see a folder called CrashPlan-install. Navigate into it by typyingcd CrashPlan-install
- Run CrashPlan install by typing./install.sh
You will be asked to accept the EULA conditions. Scroll down (by hitting space to browse an entire page at a time).
- Confirm all the default options but point 4Do you accept and agree to be bound by the EULA? (yes/no) yes
- CrashPlan will ask a final confirmationYour selections:
- CrashPlan will now install.
STEP 4: Change the default JAVA location being used by CrashPlan (This is apparently not needed from version 4.2.0 if you just let CrashPlan install its own version of Java)
You will need an FTP client such as FileZilla or WinSCP (both freeware).
On FileZilla create a new profile using the following setup
HOST: your NAS IP
PORT: Leave blank
PROTOCOL: SFTP - SSH File Transfer Protocol
LOGON TYPE: Normal
USER: root
PASSWORD: (your SSH/admin password)
- navigate to CrashPlan configuration file/usr/local/crashplan
- Edit install.vars file using your favorite editor (Notepad++ recommended)
locate the following line:JAVACOMMON=/usr/local/ (cannot remember the original path!)
replace the path it with the following: /etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java
the final string will beJAVACOMMON=/etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java
Not sure about that, isn't there a less version-dependent link under Linux? If Java is updated the whole thing has to be amended
Save the file and upload it back (FileZilla will detect the changes and will suggest to upload the file)
STEP 5: amend configuration file on the NAS
HOST: your NAS IP
PORT: Leave blank
LOGON TYPE: Normal
USER: root
FileZilla will land in the /root folder. Just browse back to navigate to the actual root (/) folder. Now you can browse/edit files without using Linux and its user-friendly interface :)
Navigate to the following folder:/usr/local/crashplan/conf
Make a backup of the file - or rename itmy.service.xml
Edit my.service.xml located in /usr/local/crashplan/conf. Use your favorite editor (Notepad++ recommended)
Find the below line<serviceHost>127.0.0.1</serviceHost>
and change it to<serviceHost>Your.NAS.IP.ADDRESS</serviceHost>.
(thanks to sdouek for the hint!)
Save the file, FileZilla will detect the changes and will ask you if you want to upload the file.
- Now restart CrashPlan (if it had ever started) by typing on the Terminal window./usr/local/crashplan/bin/CrashPlanEngine restart
- Confirm that CrashPlan is running by typingps auxww |grep -i CrashPlanService
The system must reply with something like the belowroot 4714 16.3 19.5 1262344 402020 ? SNl May30 213:54 /etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx1024m -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
root 16791 0.0 0.0 3840 504 pts/0 S+ 08:54 0:00 grep -i crashplanservice
otherwise you will receive a much less interesting answer as the belowroot 7136 0.0 0.0 3840 500 pts/0 S+ 10:29 0:00 grep -i crashplanservice
In the latter, CrashPlan has not started.
STEP 6: Connect your Windows GUI to your NAS
As mentioned, now we need to configure and manage the 'headless' CrashPlan service on your NAS. It is running but it's not doing anything because it does not know what to do. To do so we will need to fool our Windows system so the CrashPlan GUI connects to the NAS without realising so.
First, download and run the latest Windows CrashPlan client on your Windows PC. Do not run it straight away.
Next, amend the windows client's configuration. This is your Windows computer, not the NAS!
Navigate to the client's installation folder and look for a file called ui.properties.
It should be on C:\Program Files\CrashPlan\conf\ui.properties
Edit the file by using a decent editor, the default Notepad won't work well. If you do not have Notepad++ or similar, you can open it by using WordPad which is installed by default under windows.
Find the following line:#servicePort=4242
Replace it with:servicePort=4200
Next find the following line#serviceHost=127.0.0.1
replace it withserviceHost=Your.NAS.IP.ADDRESS
Save and close the file.
Next, confirm that the relevant ports are being used on the NAS. Switch to the SSH terminal window (or open a new one). Type:netstat -na | grep LISTEN | grep 42
the output should show that port 4243 is listening on the local addressusername$ netstat -na | grep LISTEN | grep 42
tcp4 0 0 *.4242 *.* LISTEN
tcp4 0 0 127.0.0.1.4243 *.* LISTEN
if you get no output, then we have a problem. Make sure that CrashPlan is running as described above.
From version 4.3.0 there is an additional step to be performed.
1 . Confirm your Windows GUI is version 4.3 and it is NOT running (you may have to kill the process "CrashPlanDesktop.exe" running in the background)
2. Connect to the NAS by FTP using ROOT credentials.
3.Copy the file .ui_info from your NAS to your computer:
.....On the NAS: .ui_info on NAS is probably located /var/lib/crashplan (unless you changed it from the default when installing)
.....On the PC: .uni_info on your desktop is located on C:\ProgramData\CrashPlan. (Rename your old .uni_info to .uni_info.orig)
Open the CrashPlan GUI on your Windows PC. It should now automatically connect to the NAS.
Click on SETTINGS/GENERAL. The NAS' name should be displayed under "Name for this computer".
Now you are configuring the CrashPlan service on the NAS. Remember: every time you need to do so, you will need to open a tunnel by opening putty as described above. If you saved the configuration (recommended), just click on ReadyNAS CrashPlan click LOAD and then OPEN. This will save you typing the same information every time.
Useful Documents/Tweaks
Instructions for the cache are here: http://support.code42.com/CrashPlan/Lat ... _Directory
You do need to preserve the linux EOL convention (either edit on the NAS, or use something like notepad++). The cache can become quite large.
Instructions for the archive directory are here: http://support.code42.com/CrashPlan/Lat ... _Is_Stored
Note this only matters of you are saving backups for other machines on the NAS (e.g., using the crashplan "friend backup" feature).
How to open a tunnel by using putty - useful to control CrashPlan remotely without having to port-forward anything more than port 22 (SSH port)
- Close all the open putty windows
- Open putty again. On the main "PUTTY CONFIGURATION" windows click on SSH and then TUNNELS on the left hand side.
- Type 4200 on the SOURCE PORT field
- Type localhost:4243 on the DESTINATION field.
- Click on ADD
Navigate to SESSION again and type the IP address of your NAS. Make sure the CONNECTION TYPE is set to SSH and port number is 22.
Because this will need to be done before running the CrashPlan GUI, I suggest you save the configuration before you connect to the NAS.
Type "ReadyNAS CrashPlan" on the SAVED SESSIONS field. Click on SAVE.
Now you can connect and establish the tunnel by clicking OPEN. Log in as usual.
From version 4.3.0 onwards there is an extra step:
edit C:\ProgramData\CrashPlan\conf\ui_username.properties (username will be your actual username)
ChangeservicePort=4243
WithservicePort=4200
Various hints and tools
#As of CrashPlan 4.2, CrashPlan will install their Java to run with their software on you NAS. There is no need to install a new Java on your whole NAS.
#JAVACOMMON=/usr/local/crashplan/jre/bin/java
#CrashPlan tests their software with that specific Java. (Unless you want to do their Quality Assurance for them on a new Java :) )
#Seeing What Port NAS is Listening to.
#Return code should look something like this:
tcp6 0 0 :::4242 :::* LISTEN
tcp6 0 0 ::ffff:YOUR.NAS.IP.ADDRESS:4243 :::* LISTEN
#Starting,Stopping CrashPlan.
#/usr/local/crashplan/bin/
./CrashPlanEngine status
./CrashPlanEngine restart
OR
/etc/init.d/crashplan [same options as above]
#Unpacking CrashPlan to install.
#/root/
#(4.3.0 change to package number you are installing)
#Installing and Uninstalling CrashPlan (This will not uninstall your .ui_info or .identity file).
#/root/CrashPlan-install/
./CrashPlan-install/install.sh
./CrashPlan-install/uninstall.sh -i /usr/local/crashplan/
#/usr/local/crashplan/conf/my.service.xml
<serviceHost>YOUR.NAS.IP.ADDRESS</serviceHost>
OR
#To have CrashPlan listen on all network interfaces and thus accepting GUI connections from any computer on your home network.
<serviceHost>0.0.0.0</serviceHost>
#If Watch file system in real time" is not working CrashPlan suggested changes so that it works on a NAS.
#/etc/sysctl.conf
fs.inotify.max_user_watches=1048576
#Increasing Memory Value to CrashPlan Engine.
#Go to CrashPlan on PC and Double Click Home Icon in Upper Right Hand Corner
#Value should be in memory increments of 64, increasing value too high will stop CrashPlan from running. The upper limit on my NAS PRO Business is 3072 and I have 8 GB of Ram installed.
java mx "value"
OR
#Stop CrashPlan
#Edit /usr/local/crashplan/bin/run.conf in SRV_JAVA_OPTS change "-Xmx3072m" to desired value.
#Start CrashPlan
#Configuring CrashPlan Backup set to Exclude all Directories Named "Recycle Bin".
#Located in Settings-Backup-File exclusions:-Configure (Make sure "Regular Expressions" is checked).
./*Recycle Bin.*
#Another way to check if the CrashPlan service is running in your PC.
#Return code should be something like this:
root 19952 80.3 7.4 3623440 611904 ? SNl 08:17 400:32 /usr/local/crashplan/jre/bin/java -Dfile.encoding=UTF-8 -Dapp=CrashPlanService -DappBaseName=CrashPlan -Xms20m -Xmx3072m -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -Dc42.native.md5.enabled=false -classpath /usr/local/crashplan/lib/com.backup42.desktop.jar:/usr/local/crashplan/lang com.backup42.service.CPService
root 23519 0.0 0.0 4104 504 pts/0 S+ 16:35 0:00 grep -i CrashPlanService- WolfieCAAspirant
Hi,
I have been running Crashplan off My Ultra 6 for about 2 years successfully.
A few days ago I had a Volume disaster and needed to factory default my system with new drives. Upon looking into reinstalling Crashplan, I came across this thread with new information since I initially set mine up 2 years ago. I've found the post "CrashPlan Headless install - For dummies . Updated for CrashPlan 4.3.0 - 07/07/2015" which is what I shall now follow to reinstall.
I just wanted to check if this procedure is still correct for Crashplan 4.4.1 which is the latest release.
Thanks for any insite that anyone may have.
Rich
- Retired_Member
Hello,
The only thing I noticed that changed since the last version of Crashplan is to copy also the IP on the right of the code in the .ui_info file from the NAS. (the IP will most likely be the one of your NAS).
- tony359Apprentice
Enterprise:/usr/local/crashplan/bin# ./CrashPlanEngine start
Starting CrashPlan Engine ... Using standard startup
OK
and if I check afterwards:Enterprise:/usr/local/crashplan/bin# ps auxww | grep -i CrashPlanService
I have uninstalled and reinstalled it but no luck.
Edit: I seem to have found a solution by following this adviceThanks to this post I found some comments that had the answer - the java path was wrong, and there was a file with one variable to fix it (http://blog.andrewkoebbe.com/posts/2014 ... dynas-102/). If you use the default installation location, crashplan installs under /usr/local/crashplan. Within that directory is a file named install.vars; where there is a variable JAVACOMMON, with a path to tell Crashplan which Java to use. The default value was the JRE inside the Crashplan installation folder - that was not working for some reason. I changed the variable to /usr/bin/java7 - pointing to the JRE installed for the entire readyNAS.
Then, I simply ran /etc/init.d/crashplan start ...and crashplan fired up and is now running fine.
Crashplan downloads its own Java during the installation. How can I prevent that from happening?
Also, my Java folder seems to be: ./etc/frontview/addons/bin/EJRE/ejdk1.8.0_33/linux_i586/jre/bin/java
Is that supposed to be? - StephenBGuru - Experienced UserYou are right, it is not running.
Maybe trycd /usr/local/crashplan/bin
and see if anything interesting is displayed (or if the service starts). - tony359ApprenticeThanks for your quick reply Stephen!
root 6439 0.0 0.0 3840 500 pts/0 S+ 10:23 0:00 grep -i crashplanservice
I downloaded this file directly on the RN http://download2.us.code42.com/installs ... _Linux.tgz - StephenBGuru - Experienced UserCrashplan for home?
What do you see if you enterps auxww | grep -i CrashPlanService
It should be something like this:root 63 0.1 6.1 873644 126976 ?? SNs Tue03PM 43:01.37 /System/Library/Frameworks/JavaVM.framework/Commands/java -Dapp=CrashPlanService -Xmn10m -Xms15m -Xmx512m -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Djava.net.preferIPv4Stack=true -Dsun.net.inetaddr.ttl=300 -Dnetworkaddress.cache.ttl=300 -Dsun.net.inetaddr.negative.ttl=0 -Dnetworkaddress.cache.negative.ttl=0 -DCP_USER_NAME= -DCP_USER_HOME= -cp lib/com.backup42.common.jar:lib/com.backup42.service.jar:lib/com.code42.backup.jar:lib/com.code42.bplusj.jar:lib/com.code42.messaging.jar:lib/com.code42.os.jar:lib/com.code42.peer.jar:lib/com.code42.utils.jar:lib/com.jniwrapper.jniwrap.jar:lib/com.jniwrapper.macpack.jar:lib/com.jniwrapper.winpack.jar:lib/jtux.jar:lib/trove-2.0.1.jar:lang com.backup42.service.CrashPlanService
- tony359ApprenticeHi all,
I'm trying to install CrashPlan on my Pro 6.
I've followed the instructions, everything is ok till step 9. Everything installs, but when I check if the ReadyNAS is listening to port 4200, the answer is NO!Enterprise:/usr/local/crashplan/bin# ps aux | grep BaseName
root 4078 0.0 0.0 3840 504 pts/0 S+ 10:02 0:00 grep BaseNamenetstat -na | grep LISTEN | grep 42
does not produce any output.
I am not massively skilled with Linux but I reckon CrashPlan has not started. I tried stopping and starting the service, it does not give error messages but I cannot see on the list of services running.
Any help? Java is running.Enterprise:/usr/local/crashplan/bin# java -version
Enterprise:/usr/local/crashplan/bin# - felixvdAspirantI tried to install this on a RN104 and finally got it running with this manual: http://blog.andrewkoebbe.com/posts/2014/06/installing-crashplan-headless-on-a-readynas-102/
I did break my admin page somewhere during the tinkering, but I don't think it was related to crashplan. The resolution for that problem is in a separate thread I posted.
Cheers
edit: I don't know why, but transfers stop after the process is running for a while. I added "service crashplan restart" to crontab to restart the process every 2 hours, and that seems to work well enough.
