zeipet's avatar
zeipet
Downgrade RN104 from 6.4.0 to 6.2.X Possible? USB Driver for PCTV 461e and serialusb do not work
Today i´ve purchased the V5 License AND installed the ReadyNAS 6.4.0 (System Break due App uninstall on 6.2.2, so i had to upgrade)
However, The OS works fine but the Stick for DVBLink will no longer detected:
"There are no compatible tuners detected on your system. For the list of compatible tuners please click here."
With ReadyNAS 6.2.2 and DVBLink 4.6.0 all worked fine, but i have no longer the license...
I´m no sure if the stick work with the 4.1.7.armada.1 kernel.
But since kernel 3.14 the driver should be in the kernel???
Can i downgrade to the kernel of 6.2.X so my enocean stick and my DVBLink PCTV 461e Stick will hopefully work.
Thanks, Peter
  • kohdee's avatar
    kohdee
    NETGEAR Expert
    You can't downgrade from 6.4 to 6.2, as 6.4 enables quotas on the file system, something 6.2 cannot support. Also, many database changes were made, so downgrading won't understand those new changes either. Upgrading to 6.4 also changes the bootloader.
    • Kortus's avatar
      Kortus
      Hello,
      I have the same problem when I made upgrade from 6.4.0 to 6.2.4 the DVBlink SW don´t see my PCTV 73se connected in USB port. Will you do some patch for resolve this problem?
    • Kortus's avatar
      Kortus
      Sorry I made mistake....
      I have the same problem when I made upgrade from 6.2.4 to 6.4.0 the DVBlink SW don´t see my PCTV 73se connected in USB port. Will you do some patch for resolve this problem?
ProSupport for Business
