espen778
Nov 22, 2013Aspirant
Drag and Drop upload won't work =(
Help!
I've got a Ready NAS 104 4-bay with 2x 3TB in RAID 1. It worked perfectly and beyond my expectations for 3-4 weeks until now.
I've been uploading my pictures throug the drag and drop function in the browser, but sudenly it stoped working. Now i can only upload files one by one, and this takes quite some time when I've got more than 1000 pics. I used Chrome while it was still working, but now I've tried both IE and firefox through LAN connection and remote, and I've also tried multiple computers where I know the drag and drop function worked before.
Any solutions? Please help! :cry:
- StephenBGuru - Experienced UserTry disabling snapshots, and then delete the snapshots that are presently there.
You could also contact support - if you are within 90 days of purchase you can phone them, otherwise use support.netgear.com - espen778AspirantWhat do you mean by disabling "snapshots"?
I do believe it's not linked to any hardware issue. It's rather something wrong in the settings of the NAS. - StephenBGuru - Experienced UserThe RN104 has a "snapshot" feature where everything you delete or change is saved into a snapshot folder. This can take up a lot of space, which could possibly be related to your issue.
If you log into the web ui, click on a share, and then select "settings" you will see "continuous protection" -> which is snapshots. You can try disabling that for all your shares. You'd then also need to delete the snapshots already saved. If you click on a share, and then "recover" you will see the snapshots. You can select and delete them.
You could also try disabling the antivirus protection, and see if that improves performance. - espen778AspirantOk, I'll try that :)
