glashoppah
Sep 30, 2015Aspirant
Failed drive replaced in Pro Business, can't tell what's up.
I've had my Pro Business for years now. I've moved from 6x500G to 6x1T to 6x2T over the years, and have always used Seagate Constellation ES.2 drives. I have a drive failure about once every 18 mon...
- Oct 02, 2015
You'd need to download them.
system.log, kernel.log, expansion.log, user.log are probably all places to look.
vandermerwe
Sep 30, 2015Master
Do you have a backup? Replacing a failed disk and the resultant resync can expose other problematic disks, you don't want to end up with a dual disk failure with single redundancy. Are you using single or dual redundancy?
Did you test the disk before you put it in?
The volume tab should tell you if a resync is taking place or not, does it? It should not take more than about 12 hours with 2 tb disks.
A reboot is usually advised if there no evidence of the rebuild starting, but I would advise you to make sure you have a backup first.
